  4. E28 SETA Build
E28 SETA Build
240 Posts 16 Posters 0 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    OK ordered what i think is all of the parts that i need to get the manual and super eta swap done last night off pelican parts! I love ordering stuff and will love it even more if my e28 would just put itself back together when the parts show up lol
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
    • RamRod E28R
      RamRod E28R
      RamRod E28
      my parts wont show up till next tuesday and i ordered monday!!!! grrr!!!! wtf pelican???!!!
        Must have been some special order stuff on there, booo!!!!
        • RamRod E28R
          RamRod E28R
          RamRod E28
          AANNNDD now my e46 trunk light dash indicator was on even with the trunk perfectly closed and also the key the handle and the trunk release button on the dash arent working lovely.... I will have to do some digging. Most likely where the wires flex when the trunk opens and closes I bet a break is in there...
            It's almost always a broken wire. I've fixed them on a handful of e46's.
              I have had to repair my e36 harness where it bends for the trunk to open as well.  Use some 3M rubber splicing tape over the whole thing once you repair the wires, it seals to itself and stretches very tight.  I use it at work for insulating lug/bolted motor wiring connections, but you can find it at at any hardware store.
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Ok... Finally got my parts from Pelican after ordering almost 2 weeks ago... not too happy about that and they didnt even send me a sticker :( and I realized that I ordered the wrong size  copper lock nuts for my exhaust studs so gonna see what options I have.
                2E17A4F5-402E-4F16-BF32-29BB1AF1F59Dzps
                659F6782-F73C-42F7-BF30-1A7191E1FC4Azps
                And found out why my trunk would only open with the key in the tumbler and why the trunk open light would stay on with it shut...
                5EFF8FEF-F10D-43F8-9527-1FD22BE1FF7Czps
                That was a fun one to get to i had to almost cut the entire boot in half to get to it.
                Some e28 getting put back together porn coming your way soon!!!
                  I hope that sticker says Wife-Beater Communist
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    As a matter of fact it does! You would not believe the amount of dirty looks I get! It's actually worse than the no fat chicks sticker with the whale below it
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      So  made some progress on the e28's super eta. I installed the new exhaust manifold studs (which go in a lot further than you'd expect). I got the old manifolds of the original eta because the super eta has a different downpipe layout over the regular eta. Also I got the oil pan off the seta which had about 20 lbs of nastiness all over it so i used about half a roll of shop towels and brakleen to get all the greasy shit off of it. Then ground off all the old gasket on the pan which is hard as a fugging rock. Gonna tackle getting all the old gasket off the block with a scraper tomorrow. Also I wanna find the ass that thought that using 26 tiny very fine threaded bolts to hold the oil pan on was a good idea and kick him (or her) square in the man (or girl) BALLS!!!
                        1/4" impact driver to remove oil pan bolts FTW!
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          We'll busted my ass on the e28 all day massive update and pics to come tomorrow!
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            Ok finally back on to do an update... Last time I left off on here was I got most all my parts for the Super ETA swap and manual swap.... Well here some pics and some info for whats been done.
                            Well I removed the oil pan and cleaned up all the nastiness and didn't get any pics of that just due to wanting to get it out of the way and wasn't all too entertaining just getting all the nasty hard gasket off and putting the new gasket on. But then I moved on to the timing belt and water pump. This was just one swipe from under the crank!
                            4A141C79-40BF-4259-AA15-F6AA2A48DAAAzps
                            Timing belt and water pump are on! That was so easy to do on the m20 (Does anyone have an M20 Water pump pulley? need one ASAP!!!)
                            2B638E5C-9CD8-466D-9A0C-BB4ED1A12720zps
                            The blurry engine has taken flight!!!
                            BF14AFD4-282D-4B8A-BC8C-61EE33630DE5zps
                            Shits about to go in
                            0280DF08-C3AD-478A-A275-0E9C5F9FC760zps
                            Going in
                            1B590CED-914A-4DF9-BCA6-CF42360C510Ezps
                            Close... But no cigar
                            E70F13CA-8272-4172-BD20-8EE04F7CB854zps
                            Finally after wiggling and jacking the trans up and down about a bajillion times I got the engine to set down on its mounts and bolted in the trans crossmember!!!
                            47D339A5-B278-4601-A1B8-DF16EEAF7487zps
                            Here's what my old trans bushings looked like compared to the new ones
                            C1CF6DEB-0E3B-46D9-A102-31428AFADD82zps
                            Starting to look like a car again!!!
                            9F4F5D62-5799-42EC-9FE5-595B469EA1F1zps
                            Bye bye gangster lean
                            3CD39565-62B7-4866-AF15-01FD949D8746zps
                            The harness is "in" lol
                            C1B050C0-5C87-433A-8245-74CF8F48FAF4zps
                            The condenser and the radiator are now bolted in place some of the hoses are set in place also the exhaust the driveshaft and the heatshield are in the car now
                            BF0E275D-E0CC-4B9C-BBC5-EE240DABFA61zps
                            The shifter is in thanks to Mr Menard for his mad fabbing skills
                            A3283DC9-5354-4619-9057-9CE0A4E07607zps
                             Just need a few things and new fluids and its ready to roll and do some maaddd!!! burnouts
                              Anything can be done with a welder, you would be doing some crazy shifting to break that bracket off lol. We got some good stuff done today, I will get the corroded nasty hose connector off of the thermostat housing this week, I picked up a brass plug for it on the way home.
                                Why dont you have a seat?
                                  With balls big enough you don't need one.
                                    southpark comes to mind
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      Chillax I do have a seat guys its just laying in the back seat. the drivers front seat install is the very last thing to do to let me know that the car is running and driveable.
                                        but what if its not, what if in a haze of mid-grade petroleum fumes, you rush to the passenger compartment to go for your initial drive, forgetting that there is no seat, and lob yourself into position only to crush your twig-n-berries on the formed hump in the unibody.
                                        I don't get the feeling that you are considering all the possible scenarios here.
                                        and for that i give this thread a 1 star rating
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          Dafuq is this thing??? http://www.stanceworks.com/forums/showthread.php?t=24047 and snap... pleezzzz vote up a little those 3 stars make me feel insufficient 😢
