  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
192 Posts 14 Posters 0 Views 1 Watching
    If you want to throw those 2.0L pistons, rods & crank my way I will gladly get them out of the way for you. :)
      bfinley
      I was going to weld them up into a table or something.
      I'll trade you for those decals ;) email me your shirt files too and I can get started on them.
      Update: all glass except the door windows are out, I think I've found all the rust holes that need to be fixed, the main debate now is patch or replace...
      There are some significant holes in the front fenders and new rockers are pretty much a given.
      I need to shuffle money around to get the 2.7 from Mike, I really hate getting paid once a month...
      My shop mates are making a run to steel mart so I should have some sheet steel to practice welding and making patches.
      I'll need to get a lesson in POR15 from Mr. Menard as well
        Just brush it on! it self levels pretty nice, I use KBS Rustseal, available at Napa.  Similar product, some have said it's better, I just use it because it's easy to get and extremely durable.
          Sounds good! I will send them to your email.
            I used nothing but KBS rust seal on my project and it is amazing! Cheaper than POR15 too. Never knew Napa carried it. I always ordered it straight from KBS and it would arrive next day most the time.
              bfinley
              Sounds good I'll try to get some tonight after work
                I would go with the gloss black, it turns out great, no clearcoat needed unless it will get alot of sun.  Don't plan on reusing the brush and it's best to use the whole can, if you have to reclose it then put a piece of plastic on before the lid or it won't come off again.
                  Yes! Do this! Speaking from experience as is JC I would imagine, lol. Also, wear latex gloves and a long sleeve shirt you dont mind ruining as once this stuff touches your skin it takes weeks to get off. Ask me how I know :P
                    bfinley
                    So I started painting the engine bay with the kbs... Completely disregarded the warning on gloves...ezu8eva2.jpg
                    Opps...
                    Also decided that despite being welded to the front valence the fenders need to be replaced and therefore be removed. No dice all the bolts are out and the finders won't budge. Inner fender is coated in a rubberized undercoat of some kind and I think it's holding the fender on. Really hoping that they aren't welded too
                      If they welded them to the bumper, you can count on them being welded on everywhere else=/
                        ^ I thought it was done from the PO
                          bfinley
                          Thought what was done?
                            bfinley
                            Went into the shop planning to clean and organize my pile of parts ...
                            Ended up wrestling the fenders off. Thankfully they were not welded on, just a nasty combo of some kind of gasket paste and rubber under coat...
                              bfinley
                              Goodness it's been a while, I've been slowly removing paint and bondo.. Gonna take it down to bare metal and build it back up. I finally got an argon tank for the welder. So after commencement I'll be patching the floors. Picked up a 2.7 eta from mike, full harness and ECU, connected to an auto trans which has already been removed. Fighting with the torque converter though.
                              so if anyone has an 885 head laying around... I want it
                              I'll get some pictures over the weekend
                              Mike and maybe John are going to come down this weekend to help me get the 2.7 eta on a stand, grind down some more paint and pull the dash.
                                bfinley
                                Dash is out, brake booster is out, steering column is out, tail lights are out.
                                Still need to get the heater core.
                                Finally down to just a shell, going to make a trip to steel mart soon and get the floors patched. Then order the roll cage next month.
                                  Looks good, I hope you took lots of pics of how the wiring goes lol.  How much interior do you plan on putting back?
                                    We dont frequently get to see the finished product of a project thread on here. I hope we get to see this one finished!
                                      bfinley
                                      The dash will go back after I add some tubing for structural integrity.
                                      John you know Mike and I aren't as meticulous as you are, we'll just remember where everything went right? ok there isn't a chance I'll rememer and we definitely didn't label them. Most everything in the dash however will not be going back. I'll be making a custom gauge cluster with lots of aircraft style switches, because I can !
                                      Snap, this car will be driving and painted by the end of the summer
                                        Do work!!  Looking good and it is good to see it being done the right way.
                                          bfinley
                                          Thank you!
                                          I don't know about "done the right way" but it's going to get done and it's going to be obscenely fun
