686 Posts 32 Posters 0 Views 1 Watching
    ClassE said:
    Normally I would - but the underside of things had a weird yellow "film" (hard to describe - thin layer of cracked yellow hue something) that did NOT want to come off. Used a putty knife to scrape it off, then needed carb cleaner and a scotchbrite pad to clean off. Whatever it was, it wasn't corrosive because it didnt etch the aluminum or steel.
    Yea that is some kind of wax, I have found that in a few places on my car too, some seem to have more than others, my e36 had it on the tops of the strut towers but not much underneath.
      ^That's cosmoline, it's for rust prevention.
        Not a bad day today. Got the trailing arm bushings and diff bushings out, adjusted the coil heights to where I "think" they're gonna be, and did some much needed cleaning in the garage.
        Tomorrow night is installing all the brake lines and getting the new bushings in the rear end!
          With the exception of the passengers line - all the original rubber lines came out like a friggen dream. Passenger front took alittle more elbow grease and my big boy panties to break loose (didn't help it was a bench/tri day so pushing was a chore). So all new stainless braided lines are installed!
          When we were bleeding some of the fluid out when disconnecting the rear lines - we pumped the brake pedal alittle bit. The passenger front piston had pushed itself out of the caliper - should I be concerned about it? It pushed back in relatively easily (what I consider to be adequate pressure to get back in). I'm thinking this is normal from pumping the brakes? I believe that was the only caliper disconnected from the carrier at the time (which is why the drivers didn't push out as well). Thoughts?
            Another day - another delivery.
            Shooting to have the car on the ground - ready to drive by next weekend!!!
              It's so fun to get packages.
                Looks like proper rubber that wont be stretched.
                What are the specs? Tread looks to me like Falken Ziex 912
                  Yeeaahh..... Nnoooo. It's gonna stretch. ;)
                  Falken 912's, I've had really good luck with the 512's and 912's for years.
                    I had a set of 912's
                    Best performance all-season tire out there IMO , gets rave reviews from Grassroots Motorsports and the treadlife is excellent too.
                    I am ready for real performance tires now so summer-only it is for me,  but the 912's are a great tire!
                      They'll be a 205/40 on 9's all around (with that width - a "proper" tire would cause clearance/fender issues and not allow the ride height I want). I'm also partial to alittle stretch for a nice flush fitment.
                      Wheels should be back from paint early next week, getting closer every night to rolling next weekend for alignment and some fun!
                      • andyhundleyA
                        andyhundleyA
                        andyhundley
                        ive bought a few sets of 512's but i couldnt get more than 10k miles out of them with rotating them frequently and everything properly aligned… but at $45 a tire, who can really complain. haha
                          Why can't it be NEXT Friday already..... ;)
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Those wheels with properly sized tires on that car... that's going to be awesome!
                              All depends on what you consider "proper" tires. :P
                              I'm shooting for that as the final ride height once finished. Hoping to be very similar in height and offset to my old white car:
                              7121AF06-62C4-4F21-B992-02DF7995D651-108
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                Well, 2 out of 3 isn't bad. :P  I guess I somehow missed the post where you said 205. Car looks great!
                                  wow, those wheels are awesome! they are like a Hartge design with a lip.
                                  Proper sized tires would be 235's or 245's on a 9" wide wheel IMO.
                                  I may try 255's
                                  I have 205's now that came on my authentic STR wheels (not fake STR's)
                                  #allforlooks
                                  #eurohatch
                                  #f***yourfakewheels
                                  #stretchedbutthoal
                                    #eurohatch.............someone has seen my instagram=)
                                      I was looking for your stuff on Instagram the other day Earl but couldn't find anything under your obvious hashtags.
                                      #nevergonnabedone #takeapartandneverreassemble #rollinhardin2018
                                      :P
                                        Without fender flares tho on a 9" wheel in front - the offset needs to be low enough to clear the coils (ET10ish). That width and offset + 235/245-anything will never fit under the stock fenders (without 4x4 height).
                                        I know the stretch/low isn't for everyone - but it is my preference.
                                          I like the wheel choice! Car is going to be stunning!
