  4. E28 SETA Build
E28 SETA Build
bmw e46 e28 jeebmw e46 e28 ran
240 Posts 16 Posters 4.1k Views 3 Watching
    Ramze46 said:
    paging cyoung im thinking we should use the super eta please explain why we should mr young
    You should just sell me your super eta and forget about it ;) Honestly if you really wanna swap it out to bump it up from 121hp to 127hp go for it, the only reason I want a super eta is because A: that was in my first car so its a first love kinda deal and B: no other reason. If it really matters Motronic 1.1 is good I guess but other than that an eta is pretty much an eta still. If your gonna swap anything I'd suggest doing what I did and swap over the dual exhaust and upgraded driveshaft which would require also swapping the output flange on the transmission.
    Unless you plan on building an "i" stroker, there isn't a reason unless you just wanna pull motors for fun . Like I said I just want one for nostalgia reasons. That or if you wanna hit that sweet, sweet 5500 rpm redline :D
      Well the engine will be out already while swapping the trans.  The only difference is the 6hp?  Are all of the sensors and other stuff the same?
      • RamRod E28R
        RamRod E28R
        RamRod E28
        6hp is all so a briggs and Stratton is all the difference so why is it called a super eta???
        1988 BMW 528e - Need parts?
        1996 Mazda Miata (SOLD!!!)
        1996 BMW 325i (Donor car)
          The only difference in sensors are what Motronic 1.1 vs 1.0 requires. I don't remember exactly what is added if anything but the crank position sensor is moved to the front of the block vs inside the transmission. This website outlines a good history of the differences for ETA's if you are curious.
          http://www.strictlyeta.net/technical/differences2.html
          • RamRod E28R
            RamRod E28R
            RamRod E28
            I love how full of shit this guy is "german edition" lol look at the bumpers dead give away moron
            • RamRod E28R
              RamRod E28R
              RamRod E28
              http://madison.craigslist.org/cto/4364505624.html
              and this I gotta say great camera work way to put some effort on the photo
              • RamRod E28R
                RamRod E28R
                RamRod E28
                http://madison.craigslist.org/cto/4351483311.html
                  Good info, so it's a different computer and harness then.  So what parts combo is an "i stroker"
                    A regular old eta bottom end and 885 head if i am correct. Or if you want high compression you use the seta bottom end.
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      So swap heads from the super eta and keep the regular eta bottom end?
                        The seta already has an 885 head.  Is the cam different?
                          Paging snap.
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            SNAP!!! also cyoung I looked at the trans and the 2 holes for the old m20 crank sensor are filled in and will have to be drilled out if im gonna stay with the old m20
                              Yes SETA's have the 885 head but it has the eta cam and single valve springs. Read this page if you wanna know all about 2.7i or "e to i" builds
                              http://www.strictlyeta.net/technical/328i_1.html
                              The other problem I ran into last night while talking to Mike was that his transmission bell housing has to have the provisions for the speed and reference sensors for motronic 1 which use the flywheel. The bell housing needs those two holes on the drivers side as circled below. I don't think it will have those holes though because the SETA has motronic 1.1 which moved those sensors to the crank pully.
                              post-2724-0-08637100-1395263542thumb.jp
                              So the options for your manual swap are:
                              • Swap G260 onto the ETA along with the motronic 1.1 harness and required sensors (which would included fixing your harness)
                              • Swap Complete SETA drive line into the car (again requiring fixing the harness)
                              • Find a compatible G260 from 1987 or earlier 528e/325e
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                Mr Menard and I will see what's what once we pull the 84 drivetrain. I'm sure we can figure something out!!!
                                  They had to make it different for one year...  This probably also means that the flywheel from the seta doesn't have the toothed ring either.  Ideally it would be nice to leave the eta in and build a 2.8i from the seta to swap in in the future.
                                  Also before you take the parts car down from the stands, get the shifter linkage out, the carrier and shift lever/rubber boot and the wire that goes through it can just come out as one piece.  The clutch master needs to come out too.  Just mentioning what I forgot while we were working on it.
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    we also need the pedal box as well kind sir so idk what im gonna do about the brakes to get it out lol
                                      I am here.
                                        You should try to get as much of that stuff out as you can before next Tuesday, then we can get started on the good car then.  I'd be up for starting pretty early.  With a long day we may be close to getting it done.  Probably going to end up swapping everything from the '88 into the '84.  Any other option will need a bunch of different parts/time.  There wasn't much bad on the harness.  And the '88 engine seems like it was taken care of decently.
                                          So after a bit of thinking today this might be really simple.
                                          Swap seta and manual into car using seta harness etc.
                                          In the future find an i cam and springs to swap in to make it an "i stroker"  Am I missing something or is it that simple?  What pistons are ideal?  And the head could also be shaved and worked over as a "next winter" project to raise compression ratio and flow a bit.
