E28 SETA Build
I guess bfinley will have to start our own jdmbimmers forum lol if I do the 1j but rather have a power plant from the motherland
It will only have Japanese Watanabe wheels! All German power!
shit is gonna get real tomorrow e28 style stay tuned!
paging cyoung im thinking we should use the super eta please explain why we should mr young
You should just sell me your super eta and forget about it
Honestly if you really wanna swap it out to bump it up from 121hp to 127hp go for it, the only reason I want a super eta is because A: that was in my first car so its a first love kinda deal and B: no other reason. If it really matters Motronic 1.1 is good I guess but other than that an eta is pretty much an eta still. If your gonna swap anything I'd suggest doing what I did and swap over the dual exhaust and upgraded driveshaft which would require also swapping the output flange on the transmission. Unless you plan on building an "i" stroker, there isn't a reason unless you just wanna pull motors for fun . Like I said I just want one for nostalgia reasons. That or if you wanna hit that sweet, sweet 5500 rpm redline
6hp is all so a briggs and Stratton is all the difference so why is it called a super eta???
Well the engine will be out already while swapping the trans. The only difference is the 6hp? Are all of the sensors and other stuff the same?
The only difference in sensors are what Motronic 1.1 vs 1.0 requires. I don't remember exactly what is added if anything but the crank position sensor is moved to the front of the block vs inside the transmission. This website outlines a good history of the differences for ETA's if you are curious.
I love how full of shit this guy is "german edition" lol look at the bumpers dead give away moron
http://madison.craigslist.org/cto/4364505624.html
and this I gotta say great camera work way to put some effort on the photo
Good info, so it's a different computer and harness then. So what parts combo is an "i stroker"
A regular old eta bottom end and 885 head if i am correct. Or if you want high compression you use the seta bottom end.
So swap heads from the super eta and keep the regular eta bottom end?
