    I think Rowley is misunderstanding, vented rotors have the air space between the two sides but the braking surface is smooth, not the same as slotted with the grooves in the braking surface.  In general, solid rotors are usually used on the rears where less cooling is needed.
      I see where the disconnect is. I wanted the double slotted pattern on vented rotors. The vented and solid refers to the build of the rotor blank itself like John said. I wanted Adams Rotors for the great quality and they cost the same blank as they do being machined.
      I opted for the AR Race (double slotted) pattern because it is one of the patterns that adds a hair of performance and also looks good. The dimpled/drilled rotors don't really offer much when used with street pads and they also make noise.
        True, but I just want to have what the car already has instead of downgrading to solid=) If you prefer solid, would you like to by my solids for your e36? =D
        Solids on a pure race car= no no :)
        I completely understand what you guys are saying now.
          Why do you even need brakes, I mean aren't the frame rails against the ground going to be able to stop the car just fine?? :P
            You are silly=)
              No real update.
              I didn't get out to the shop this weekend. My buddy Kyle will hopefully be out this weekend to put in more time on the bay.
              I have a pending order on ECS for the tensioner plug and washer, as well as all new bolts for the front suspension. I am trying to replace almost every bolt with a new one for peace of mind. When I did the rear suspension I didn't really care all that much. Now I feel like rusty hardware was half-assing it and I feel like ripping it back out to replace all of that as well.
              I have also been thinking about my rear shock mounts. I have some decently new e46 m3 convertible mounts installed now, but I didn't have new washers, nuts, and gaskets when I put them in. I have been thinking about doing the GC tall RSM's to gain some dampening in the rear, but I think that would limit my airing up height due to the Mustang shocks already being really short.
              I am also hearing about Camaro rear shocks lately and am wondering how they compare length wise and stiffness wise to the mustang shocks. Does anybody have any info on this?
                I'm all ears on the America muscle shock info. I'm in the market for some rears.
                  Here is a Bilstein HD compared to the 97 Mustang GT shock.
                  If someone can find a comparison pictrue for the camaro rears that would be great. I am not having any luck.
                    Found this: http://grippysgarage.com/2011/09/03/camaro-shock/
                    p1030404.jpg?w=540
                    They look either the same or maybe a hair longer than the Mustang shocks, but they do have cheap adjustable dampening shocks available.
                      Currently I have these molding badges
                      I have never been a huge fan of them since my car isn't an ///M car.
                      However, I have always been a huge fan of these
                      Since I have ///M parts this seems more fitting and looks a little nicer.
                      Thoughts?
                        Better for sure, also what about the motorsport ones?  They are my favorite.
                          Those are nice too. I like the M-technic ones a little more. If I really wanted to get something to reflect what my car has become, I could get Clubsport badges=)
                            I don't like the colors on the M technic....however I agree with you not wanting to pose as an M.
                              M Technic all the way!
                                Not a ton done this weekend.
                                Saturday I went out to the shop and threw my front subframe and sway bar in the trunk to clean up at work this week. I think I will have my front subframe reinforcements TIG'd in at work as well.
                                My proper Adams Rotors came and I also picked up my powdercoated calipers, carriers, and knuckles.
                                I also ended up talking to a guy who does vector images and asked how he does them. I realized I didn't have the tool to do it, but he offered to do one of my car. He did an awesome job. He even modeled my AC  Schnitzer Mirrors.
                                His name is Artur Borovik. Here is his portfolio: http://arturborovik.com/
                                  Looking good, I have a bunch of parts getting powdered right now.
                                    The vecotr is cool....doesn't appear to be low enough.
                                      He made the frame rails a little high. E36 rockers sit so high compared to the frame rails.
                                      Edit: Starring at it on my large computer screen seems that it is a tad higher than it should be. Other than that it is pretty accurate to the end product, minus the trim badge, tinted windows, wipers (front and rear), and pig nose grills.
                                        Looking good sir, looking good! :D
                                          Pretty neat stuff Earl.
