    If you told them vented with the order then it is their fault.  They should have contacted you if they were in doubt.
      I just told them that I needed rotors for a 1995 318ti. At the time I wasn't aware that there were two options for the front. Since Centric doesnt list vented fronts for a 95, they made solids.
        If your rotors are the same as the 98/99 vented rotors, why cant you just order 98/99 vented rotors from them if their catalog shows vented for those years? Or am I missing something?
          why do you even want vented rotors?
            The thing is that my car came from the factory with the option for vented fronts. I ordered rotors for a 1995 318Ti because that is what I have. Since they never asked about vented or solid fronts, I figured they were making what I have (it never crossed my mind that there were two options for front rotors). When they arrived I then noticed that they gave me solid fronts and that they did not know that cars older than 98 came with vented fronts.
            They are giving me the option to get the vented fronts but I have to pay an additional $50 to cover partial material and shipping costs. I do however get to keep the solid ones as well.
              Because my car came with/is set up for vented rotors. Why would I pay this much money to have a downgraded set of rotors? The solid rotors will heat up a lot more and are a lot skinnier than the vented rotors.
                Well in that case, I understand! I definitely perfer solid over vented and such because you don't need it unless you are tracking the car, and you can't resurface vented/slotted normally. Heat really isn't an issue unless you track it.
                  True, but I just want to have what the car already has instead of downgrading to solid=) If you prefer solid, would you like to by my solids for your e36? =D
                    I think Rowley is misunderstanding, vented rotors have the air space between the two sides but the braking surface is smooth, not the same as slotted with the grooves in the braking surface.  In general, solid rotors are usually used on the rears where less cooling is needed.
                      I see where the disconnect is. I wanted the double slotted pattern on vented rotors. The vented and solid refers to the build of the rotor blank itself like John said. I wanted Adams Rotors for the great quality and they cost the same blank as they do being machined.
                      I opted for the AR Race (double slotted) pattern because it is one of the patterns that adds a hair of performance and also looks good. The dimpled/drilled rotors don't really offer much when used with street pads and they also make noise.
                        Solids on a pure race car= no no :)
                        I completely understand what you guys are saying now.
                          Why do you even need brakes, I mean aren't the frame rails against the ground going to be able to stop the car just fine?? :P
                            You are silly=)
                              No real update.
                              I didn't get out to the shop this weekend. My buddy Kyle will hopefully be out this weekend to put in more time on the bay.
                              I have a pending order on ECS for the tensioner plug and washer, as well as all new bolts for the front suspension. I am trying to replace almost every bolt with a new one for peace of mind. When I did the rear suspension I didn't really care all that much. Now I feel like rusty hardware was half-assing it and I feel like ripping it back out to replace all of that as well.
                              I have also been thinking about my rear shock mounts. I have some decently new e46 m3 convertible mounts installed now, but I didn't have new washers, nuts, and gaskets when I put them in. I have been thinking about doing the GC tall RSM's to gain some dampening in the rear, but I think that would limit my airing up height due to the Mustang shocks already being really short.
                              I am also hearing about Camaro rear shocks lately and am wondering how they compare length wise and stiffness wise to the mustang shocks. Does anybody have any info on this?
                                I'm all ears on the America muscle shock info. I'm in the market for some rears.
                                  Here is a Bilstein HD compared to the 97 Mustang GT shock.
                                  If someone can find a comparison pictrue for the camaro rears that would be great. I am not having any luck.
                                    Found this: http://grippysgarage.com/2011/09/03/camaro-shock/
                                    p1030404.jpg?w=540
                                    They look either the same or maybe a hair longer than the Mustang shocks, but they do have cheap adjustable dampening shocks available.
                                      Currently I have these molding badges
                                      I have never been a huge fan of them since my car isn't an ///M car.
                                      However, I have always been a huge fan of these
                                      Since I have ///M parts this seems more fitting and looks a little nicer.
                                      Thoughts?
                                        Better for sure, also what about the motorsport ones?  They are my favorite.
                                          Those are nice too. I like the M-technic ones a little more. If I really wanted to get something to reflect what my car has become, I could get Clubsport badges=)
