  4. 1992 525it with an M30B35 Swap
95 Posts 15 Posters 0 Views 1 Watching
    if you do a big turbo id do an electronic boost controller to help with low rpm crap
    -someone that doesnt know anything about turbos, but the logic seems sound.
    Megasquirt for the win!
    • L
      L
      Laishes
      So after a nice drive up to Green Lake Wisconsin yesterday; me and Rowley found out a few things...
      One of the subframe bolts is completely missing
      The engines leaking some oil out of the oil pan gasket
      The underbody is spotless. same with the rockers. However, both front fenders will most likely need to be replaced at some point due to them rusting on the bottom.
      My wagon and snow do NOT mix.
      A turbo will eventually be added
      The plan of attack you ask???
      Well...
      Most likely the subframe will have to be dropped to access the bolt (am i wrong?) after that is done we'll most likely do the oil pan gasket with a fresh oil change.
      Wire wheel and sand any surface rust that is on the doors/body and prime it to prevent it from rusting further.
        only minor surface rust past the fenders! woohoo
        AKA HE SLID INTO THE DITCH :)
        Well...
        Correct. Has to be dropped to remove old one..
          Slid into the ditch..... The first great rage drift of 2014 has happened
          • L
            L
            Laishes
            Lol yup. Not used to the torquey M30 😢
              Sounds like you were texting while driving / DUI / roadknob / dreaming about M20 swaps.
              • L
                L
                Laishes
                Sounds like you were texting while driving / DUI / brain / dreaming about M20 swaps.
                I may have been under the influence... of something..
                Nope... Nope... Nevermind....
                It must've been the m20 swap daydream.
                  He put it into 3rd, about 2500 rpms, down a hill, and that was enough torque to lock up the lsd haha. I thought he was joking around. HE WASN't
                  I'M FAUKING SORE FROM DIGGING MY ASS OUT YESTERDAY(and his..)
                  • L
                    L
                    Laishes
                    Rowley...
                    We probably should've checked to make sure the old one was still in there with a screwdriver and a flashlight or something
                    • L
                      L
                      Laishes
                      I even had the clutch partially in going down hill. I don't know what % lock my LSD is but holy shit...
                      Not to mention my tires aren't made for the snow or they don't have enough tread... minaswell be on ice!
                        Laishes said:
                        Rowley...
                        Yea I said that after we went back to my house... We're good at this.
                        • L
                          L
                          Laishes
                          I'll try and check today. because if the old one is out we wouldn't have to drop the subframe?
                            Correct. I just thought because he said he torqued it down and it broke it would be in there?
                            • L
                              L
                              Laishes
                              Awesome; I'll check today to make sure the old one isnt in there; and to make sure i cant get it out
                              • colorowleyC
                                colorowleyC
                                colorowley
                                Mitch and this kid love ditches!!!
                                • L
                                  L
                                  Laishes
                                  Hahahaha
                                    LOLOL I'm glad someone had a picture...
                                    • colorowleyC
                                      colorowleyC
                                      colorowley
                                      Always taking pictures bro!
                                      • colorowleyC
                                        colorowleyC
                                        colorowley
                                          If any mods would like to make that my profile picture, it would be great :)
