  4. 1992 525it with an M30B35 Swap
95 Posts 15 Posters 0 Views 1 Watching
  • L
    L
    Laishes
    Edurty said:
    There's a "build thread" on bimmerforums for this car. Its been around and heard many people say to stay away from it. As long as it was worth it yo you
    Minus the surface rust; mechanically it's in great shape. I even checked out the rockers and they are clean aswell. So far I've noticed nothing but good things about this car-- it's solid and well put together
      Dude even it's a pile you got it for nothing. Well, pretty close.
      • L
        L
        Laishes
        Yeah no doubt Rowley;
        I saw the forum Baxters talking about.
        It's just a bunch of people from the south (who probably have never even seen rust before) saying "That cars past its prime" due to the fact it has minor surface door rust.
        The P.O. who originally built it drove it in the winter but kept good care of it.
        I don't care what anyone says;
        I like it; it was super cheap (by my standards atleast);it's MY car; it's rare; and until I find out its totally rotted to hell and unrepairable (Looks relatively spotless actually..) I won't be getting rid of it anytime soon!
        It's the first EVER M30B35 swapped touring in the U.S. and the swap is proper as fuck.
        Baxter likes his E30 but won't sell it for anything less than 6k. Everyone thinks thats over priced. Does Baxter care? No. It's his car; he likes it; and that's what he'd sell it for.
        My E30 was far from a perfect car and I also got cash ontop of the trade so I'm very happy.
        H8ers gunna H8.
        Or people are jealous that they don't have a swaggin' waggin'. who knows, right?!
        • L
          L
          Laishes
          Rowleym said:
          What I'm saying is you won't be able to make 500whp on a stock m30 with hx35 because you would need boost pressures of 35+psi and that's not happening. I was saying you would make around 350whp on an hx35 on that motor with a decent amount of boost. With e85 I bet 450.
          I'll have to run a HX40 to get over 450whp?
          I suppose your right!
            I'm a big fan of that turbo. Best for a street car. Just over the size of a gt35.
            • L
              L
              Laishes
              Rowley;
              Gunna come help me wrench on it?!
              Install that HX40 soon?
                Rowley;
                I would love to come work on it! Haha you can buy my hx40 whenever you would like, I want bigger. And if you are serious about turboing it, I have a completely portable welding setup. My tig plugs into 110 and 220 so I can weld nearly anywhere. Also have portable welding cart and table. All fits in the back of the Subaru :)
                • L
                  L
                  Laishes
                  This is super good news!!
                  Would you be comfortable welding in sheet metal to fix rust?
                  I havent gone super "into" the car but I'm sure the start of the rockers need a little love.
                    Sheet metal is super easy to tig. Lower heat so it doesn't warp like mig. I'll even teach you so you can just do it yourself haha
                    • L
                      L
                      Laishes
                      I don't have a garage so I would most likely be coming to you?
                      I sent you a PM with my number just toss me a text
                      • L
                        L
                        Laishes
                        Brian. said:
                        Also, double check it's a B35 head. Could be a B34, not a biggie, but that little bit would go a long way! :D
                        Its a B35; was pulled out've an 89'
                          That's worth some money right there too as you have the stronger early block. You're set for doing a turbo build!
                            He is coming over Sunday and we shall ponder up some ideazzz
                            • L
                              L
                              Laishes
                              The ideazzz will be cooking.
                                if you do a big turbo id do an electronic boost controller to help with low rpm crap
                                -someone that doesnt know anything about turbos, but the logic seems sound.
                                  Megasquirt for the win!
                                  • L
                                    L
                                    Laishes
                                    So after a nice drive up to Green Lake Wisconsin yesterday; me and Rowley found out a few things...
                                    One of the subframe bolts is completely missing
                                    The engines leaking some oil out of the oil pan gasket
                                    The underbody is spotless. same with the rockers. However, both front fenders will most likely need to be replaced at some point due to them rusting on the bottom.
                                    My wagon and snow do NOT mix.
                                    A turbo will eventually be added
                                    The plan of attack you ask???
                                    Well...
                                    Most likely the subframe will have to be dropped to access the bolt (am i wrong?) after that is done we'll most likely do the oil pan gasket with a fresh oil change.
                                    Wire wheel and sand any surface rust that is on the doors/body and prime it to prevent it from rusting further.
                                      only minor surface rust past the fenders! woohoo
                                      AKA HE SLID INTO THE DITCH :)
                                      Well...
                                      Correct. Has to be dropped to remove old one..
                                        Slid into the ditch..... The first great rage drift of 2014 has happened
                                        • L
                                          L
                                          Laishes
                                          Lol yup. Not used to the torquey M30 😢
