  4. 1992 525it with an M30B35 Swap
95 Posts 15 Posters 0 Views 1 Watching
  • L
    L
    Laishes
    you and straight6pwr need to engage in a wagon race.
    Snap, I also decided that I would've missed the old 12v sound and backfires which is why I decided to trade. I think the M30 picks up where the M20 left off (timing chain + more displacement and reliable to 300k) and I thought it was cool to have in a wagon. Kaiser's car is quick but it was almost too smooth for my taste
      Hell yeah! This is what I'm talking about :D Welcome back to the 5er family.
        Need more pics!!!
          I get to be an asshole now:
          -Timing belts waste less power than timing chains
          -An M20 timing belt change interval is 60k miles, that's  once every 4 years on your average daily driven vehicle.
          -Timing sprockets get worn down and timing chains jump timing (for any non-believers: http://forum.roadfly.com/threads/12565880-735i-(M30)-Timing-Chain-Jumped)
          -Timing chains stretch, chain guides wear out, tensioners wear out, bad noises are had and you will end up having to dig into the car to replace them anyways (then factor in the cost of a new chain, new sprockets, and all other timing chain components since you are already in there and heaven forbid you tear into the engine this far ever again because you were trying to avoid this type of thing by purposely avoiding an engine with a timing belt).... this is more involved and far more money than your once every 4 years timing belt change would ever be.
          -As of a month ago Gates started making a "racing" timing belt for the M20. not that any of the 500+hp  turbo M20s had problems with the stock belt anyways.
          Theres nothing wrong with timing chains, they are a good thing, but there is also nothing wrong with timing belts. People that despise them are likely too cheap to do most other preventative maintenance either.
          /soapbox derby
            sweet e34 touring.
            the 5 speed is a great addition, although personally i would say the m30 is a backwards step from the m50.
            i would love to ride in it sometime to see what a touring with suspension drives like compared to stock!
            • L
              L
              Laishes
              When is this not the case ;)
              I'm just afraid of the timing belts on these old cars.
              P.O.s "say" it was done 20k ago but was it really? How would you ever know?
              Having a timing chain is just extra assurance; not saying the belts are bad whatsoever--the m20 engine will go forever
              • L
                L
                Laishes
                sweet e34 touring.
                It rides O.K.
                I wish it was lowered on coils but the H&Rs arent too bad.
                Not too much body roll in the corners at all.
                And I think the M30 is about on par with the M50 personally; the M50 is just more modern and "smooth"
                  We are turboing it I don't care what you say.
                  Build thread:
                  some big injectors
                  walbro in tank-100
                  hx40-150-400
                  arp studs-200
                  ms2-300
                  cheap intercooler that fits-100-200
                  Ill build the manifold from scraps.
                  Some ebay clutch. 300 tops
                  DONE. Shits cheap.
                    Build thread:
                    some big injectors
                    walbro in tank-100
                    hx40-150-400
                    arp studs-200
                    ms2-300
                    DONE. Shits cheap.
                    Hodge podge turbo builds are cool, if done on a car that no one gives 2 fucks about. but as a daily as well as a touring, I'd suggest going a legit build, if he were to even go turbo route.
                    Also, double check it's a B35 head. Could be a B34, not a biggie, but that little bit would go a long way! :D
                      Please tell me an item on that list that isn't legit.... Well except the clutch, but many many people have had success with f1 clutches.
                        home brew manifold, for one. RARELY turns out well. and RARELY performs like it should.
                        Cheap intercooler.
                        hx40 - still to big
                        Just saying.
                        • L
                          L
                          Laishes
                          Rowleym said:
                          I'm gonna build an e34 wagon with a big turbo m30 in it some day!! Mad jealous. Love e34 wagons. I've been looking forever for a manual one around here.
                          Build thread:
                          some big injectors
                          walbro in tank-100
                          hx40-150-400
                          arp studs-200
                          ms2-300
                          DONE. Shits cheap.
                          Hahaha!
                            Cheap intercooler.
                            hx40 - still to big
                            Just saying.
                            BUllllllllshit.
                            Anything smaller than an hx40 and you would have full boost..... alll the time. I don't believe in turbo's in a daily that spool before 3500. Its just ridiculous.
                            cxracing intercoolers have definitely been proven many many times, and there is no need for a 1000$ intercooler when you have a stock block.
                            And you think I can't design a manifold? I wouldn't need to. Just copy a simple design. Sure I probably couldn't build the best twin scroll equal length manifold, but shit I have all the tools and materials to build a m30 manifold right now.
                            Why else would I have bought a brand new tig welder?
                              Laishes said:
                              Hahaha!
                              So. How much would you sell it for? And hint, the answer is not "I don't want to sell it" :)
                              • L
                                L
                                Laishes
                                Not fo' sale
                                I got this thing for a steal considering I bought my e30 for $1400
                                  Laishes said:
                                  Not fo' sale
                                  I hate you... and Yes I completely understand the steal. Just not fair :)
                                  • L
                                    L
                                    Laishes
                                    You could always swap your own!
                                    I looked it up however and the swap seems very daunting. It's a difficult swap for sure.
                                    • L
                                      L
                                      Laishes
                                      I do want to turbo it eventually but I wont have any of the funds soon enough unless I sell my daily driver
                                      • L
                                        L
                                        Laishes
                                        Rowleym said:
                                        BUllllllllshit. Anything smaller than an hx40 and you would have full boost..... alll the time. I don't believe in turbo's in a daily that spool before 3500. Its just ridiculous.
                                        Just because it's a wagon doesn't mean it won't be garage queening it up!
                                        I have my trusty toyota corolla as a daily driver
                                        Personally I would most likely run an HX35 for my setup?
                                        • L
                                          L
                                          Laishes
                                          More picss
