    I think your refinement is off.  There looks to be a little dog in there too.
        You guys just made my day. Hahahaha
          Hahah. 10/10. Would read again.
            LMFAO!!!!!!
              Again. I love this place. Thank you snap.
              • andyhundleyA
                andyhundleyA
                andyhundley
                That put a huge smile on my face!
                  What did you do to get the fusebox out?
                    NM, found your post on BFC, if anyone else is wondering.
                    http://forums.bimmerforums.com/forum/showthread.php?1948071-E36-fuse-box-relocate
                    Where did you put everything?
                      It is being tucked under the kick panel of my dash. The top left bolt is a huge pain to get at. The headlight harness also needs to be extended about a foot. The other issue is figuring out how to route your engine harness so that it can attach to the connector from the fusebox.
                        I dont want to relocate mine, just to be able to paint.  I got the four screws out that hold it to the firewall which may be enough, it moves a little now.  Not sure about getting the screws back in though...  I will worry about that later lol, thanks!
                          The lid needs to be removed to get it to move. It has four screws around it. You have to tug up hard to get it up. After that you need to remove the lower portion of the box. It has a plastic piece that needs to be removed to allow it to separate from the wiring. It is pretty easy to get moved once you get the lid off.
                            My Adams Rotors showed up Friday.
                            There was a miscommunication between Adam and I on the front rotors. Compacts end up having the option for either solid or vented fronts. My car ended up having the vented option, but Adam assumed it had the solid option. No biggie whatsoever. He was very happy to sort this out with me and it luckily happened at a time where they aren't needed ASAP anyways.
                            My buddy Greaser Kyle did more work in the bay.
                            We want it to be mostly symmetrical when it is done. There was an odd bump on the drivers side frame rail where a mount used to sit. It was ground off and patched.
                            He also patched an indent in the drivers side tower but I forgot to take an after picture=/
                            He ended up finishing the patch on the inside of the passenger side tower as well to rid of the tear drop shaped indent. (I forgot to picture this as well)
                            While this was going on, my friends and I procured the cam lock tool and made an attempt to get the timing chain on and then engine timed. I think we got it but I am too afraid to turn it over. lol
                            I was going to install the M44 tensioner (upgrade over the M42 tensioner) but I didn't seem to order a new seal and cover to install it=/
                            Other than that I have been thinking about sideskirts lately and how I don't think the ///M skirts will be good enough. I have been told e46 skirts are the same length but cannot find any good pictures of e36's running stock e46 skirts. I will be looking into my options.
                            I also took this picture while I was walking around #rippinshelfies
                              Even if the motor is slightly out of time, you won't hit any valves/pistons together. So turn it over at free will(if it's tensioned)!!! And if it hits anything, stop and do it again :) I would advise to do so before you actually put it in/together.
                                Adams Rotors?  They look like Earls Rotors to me!  see what I did there?
                                  Thanks for the heads up. Should I install the tensioner with the old plug and washer for now just to check this out?
                                  I see what you did there=)
                                    Just leave the tension tool in there, turn it a couple turns and check that the cam lock tool fits back on or is dang close.  You won't wreck anything turning it by hand, you would feel if something hit.
                                      I have a new tensioner since the m42 one exploded when I removed it. lol I will get it in this weekend and see what is up. So I will know if it is timed right if it spins over without hitting anything correct? I just want to make sure I am getting this right.
                                        Yep, you are way over thinking it, it's super easy.
                                          I feel much better about this now=) I love this forum=D
