pistonse30
    Buy a 50lb bag of kitty litter and get spreadin!! Good to hear about the fully torqued vanos bolt.
    That doesn't look like cat poop.
    Kitty litter, oil dry. Works pretty much the same.
      good to know, i will see how my cat likes oil dry
        Nicely done on that bolt scavenge. I am pretty damn sure I dropped a nut down the timing chain when putting my head back on, but still cant find anything. I have since fired her up and drove her around the block and nothing bad happened. Lol.
          I did pick up two bags of oil Zorb on the first of three trips to the hardware store. Haven't spread it out though. Tomorrow!
            List of to do's to keep me on the up and up:
            - Tighten up heater core coolant hoses on firewall. DONE
            - Teflon seal MAP (?) sensor under intake manifold.  DONE
            - BOV vacuum hose.
                - Make line and install.
            - Pop valve cover on and coils.  DONE
            - Install radiator and fill with BMW's version of liquid gold of the blue tint, distilled water and water wetter.
            - Change oil with cheap stuff and drive for 10 minutes.
            - Change oil and filter with good stuff.
            - Track down why the AFR gauge stopped working, again...
            - Up the boost and head to the dyno.
              What AFR gauge are you using?  I have been looking at the Innovate one but am open to suggestions.
                Are you going back to LMT to dyno it? I'd like to see you make a few pulls!
                  by the wideband "not working" is the gauge receiving power but not getting a signal from the sensor?
                  If so, check the sensor and gauge grounds. I have an Innovate MTX-L, and love it, but it wouldnt let me use the ground on the factory O2 connector. It wouldnt get enough voltage from the car and threw an error code (very picky about grounds)
                    PLX Devices.  I like it, when I get it to work.  It hasn't worked because of my own doing to first time and I think I know why it went south again.
                    I think so.  It would probably be good to keep it consistent to compare numbers.  And it didn't burst into flames there so that's that.  I'll let you all know when I schedule a date with LMT so you can see the Doc be a nervous wreck.
                    No power to the gauge.  I pulled out the + wire in the power connector they included in the kit while adjusting the wires so I could crimp the in-line fuse that I was installing.  Radio shack doesn't have that power plug thing so I soldered it back together to work but it wasn't the doc's best showing.  After I get it running I'll track it down.
                      I am interested in attending the dyno session as well
                      • mkoeppM
                        mkoeppM
                        mkoepp
                        ^^ X2 :)
                          I'm about to ask a question about where and who dyno's this car, but should I just open a thread  about midwest dyno's or something? I would love to find more places to bring cars you knoooow
                            I went to Late Model Throttle when they had a dyno day aka half off dyno runs.
                              Count me in on this dyno run too!
                                We should turn it into a guessing game.
                                Guess the peak HP and win a date with Kaiser?
                                  To a restaurant of your choice
                                    If I guess 550 and end up putting it down we're eating steak!
                                      With a proper tune this should be easy.
                                        I just really want a steak date...
                                        This dyno run will be a base to send to trm for tweaking.
                                          Quaker Steak...
                                          ..and Lube.
                                          what are you going to turn the boost up to for this ?
