Chapter GMW | E30 LS1 (starting on post #1427)
Great article! Great build. I can't begin to think how insane it must be. I would like a ride someday
Let's do that!
Looks great man! That car is a hell of an accomplishment! Ditto on the ride someday.
Thanks a lot!!
I'll give rides in the car out like I give kids candy!
^hahhah
Drove the e30 the other day with the trans mounts. It is a little more noisy and there are some more vibrations but nothing that was too bad. We'll see how long that lasts. As for performance I have no clue. Too cold to have fun without freaking myself out.
This is why you need an M20. Then you could have fun (maybe) without freaking yourself out.
Haha. When it warms up I want to look like this but with more hair.
http://www.tialsport.com/documents/w3_tial_qqr_sp.pdf
I need to get a bigger i.d. line to support this BOV. From there I'll tackle the fluttering if it is still happening at 20+psi.
Everyone remembers that iconic douchebag lol-
My next little undertaking that needs to be done to get this thing close to 100% right:
- Switch my heater core hoses on the firewall. I read a couple of places that if you have them incorrect you will only blow hot air at idle and get cold air at speed which are my current symptoms. DONE
- While my hands are tucked in there I'm going to install my adjustable FPR.
- With the coolant coming out of the car I will pull my radiator to 1) completely drain the system as much as I can to get fresh coolant in there just for peace of mind, 2) deal with a striped bolt on my vanos cover (ugh!) and 3) RTV seal + reinstall the vanos cover gasket. I'm 99% this is where the oil leak is coming from. An educated guess by the DOC. DONE
- Fill with distilled water then drive to my buddies shop where he can pressure fill the system with the liquid gold aka BMW blue coolant, water wetter and distilled water.
- While there do an oil change with royal purple and take a oil sample and send out to get tested to see what she is sweatin' off in there.
- Replace the current BOV vacuum hose with a 1/4" I.D. braided line.
If all goes well with the oil leak and BOV I'll then change the boost to low 20s psi. and have a beer.
Busy day there.....I like what your doing and I will take you up on that ride
in better weather....Actually looking forward to it. I would like to get to know more about boosting in general....Thanks for posting your progress.....
I do have my work cut out for me on this day. Whenever that will come. Probably within a week or two.
In sub teen temps with the 215mm tires I might as well not give it more than half throttle. I forgot to mention I will be popping my 235's on soon just to rock in this salt. Those rims are cheap ESMs. Pretty frustrating but it will make me get this thing 100% right before the warm weather comes so I can just drive!
Soooo I just snapped the tapper in the vanos cover hole. %*&%#@$!! Time to walk away for a bit.
I'm thinking of getting a reverse threaded drill bit and see if it will back itself out. Does anyone know how much extra material is surrounding those holes? Oh god.... I actually might just take that cover off and see what I can do then.
On a slightly positive note there was oil on the bolt when I took it out leading me to believe that the oil leak is coming from that gasket
This cold weather is a dickhoal.
I was installing a head stud yesterday, almost torqued down, then SNAP
(unfathomable rage and fear, imminent death, and all the foul things of the world all concentrated into a tiny particle and then vomited upon the expanse of my ambiance ).
Some oil in the bottom of the hole prevented the stud from going down further and the cold caused the stud to pull out 2-3 threads from the cold brittle cast iron block. I was able to clean out the hole and thread it back in with plenty of engagement left so all is well in the world, but still. I nearly cried.
My oil filter housing already fell victim to the cold last week. That was bad enough.
Good luck with that tap.
This cold sure does a number to ya mentally, physically and spiritually.
Tried to drill a tiny hole in the tap to fit a reverse thread extractor but the bit just dulled up right away so I stopped. Back on break time. I might just have to drill and tap to a bigger size.
I am sure you will figure out a great solution, but damn does that sound like a heart sinker situation. I hate those. Hoping for the best for both of ya!
This type of stuff really tests me. I have some credit at Kummrow from them putting the head and cams in and I might have Pat do the tapping for me. I have a call into him just waiting for a response.
I also got the heater hoses off of the firewall and now I just need to pop them on the right way. Tomorrow I will head out to Pegasus to get a thicker vacuum hose setup for the BOV.
M50) said:
