  4. E46 running warm?
E46 running warm?
19 Posts 5 Posters 0 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    Just ticked over to 120k and all the cooling system was replaced at 90k
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      Thermostat is easy. Just do it, much better than the consequences of overheating the car.
        Yep, I have done 2 full rebuilds and a head replacement because of overheating, seems early for failure if you just replaced everything at 90k.  Maybe the thermostat wasn't very good to begin with.  Get a quality one, be careful of local parts store replacements.
          I have had new thermostats stick closed partially. I have also had a few friends with sticking thermostats that were brand new.
          • RamRod E28R
            RamRod E28R
            RamRod E28
            Ok I'll jump right on the thermostat then... It's been fine today so far
            • H
              H
              Hammerdown
              E46 failed thermostat will be in the OPEN position. Easy fix on manual but have to take the fan off on an auto.  Wise to replace water pump while in there. I didn't and  to this day could kick myself.
              Keep an eye on temps over the next couple days- it may have been high as a fluke. Or even paper or plastic stuck on the grill and fell off while at work
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Trust me I've been keeping an eye on it all the time.
                • RamRod E28R
                  RamRod E28R
                  RamRod E28
                  So weeks have gone by and it's only doing I when I let the car sit for over 16 hours so I'm thinking thermostat...
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    And after sitting it has to be 10 degrees or colder for it to do it
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      What thermostat do you guys recommend for replacement?
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        Bump
                          Oem
                            ^ what he said. Don't go cheap.
                            • RamRod E28R
                              RamRod E28R
                              RamRod E28
                              Pelican parts?
                                Yep, they probably sell a couple different ones. Don't have to get the one that says OEM, choose another mfg that says OEM supplier. Same part without the BMW sticker on the box.
