E46 running warm?
How much of a bitch is it to do?
i am not exactly sure on an e46. On an E30 its a matter of 10 minutes. Perhaps watching this will give you an idea of what it would take, even though they replace the water pump also.
http://www.youtube.com/watch?v=bA8GPapQnqY
how many miles do you have on the car and when was the coolant last changed?
Just ticked over to 120k and all the cooling system was replaced at 90k
Ok I'll jump right on the thermostat then... It's been fine today so far
E46 failed thermostat will be in the OPEN position. Easy fix on manual but have to take the fan off on an auto. Wise to replace water pump while in there. I didn't and to this day could kick myself.
Keep an eye on temps over the next couple days- it may have been high as a fluke. Or even paper or plastic stuck on the grill and fell off while at work
Trust me I've been keeping an eye on it all the time.
So weeks have gone by and it's only doing I when I let the car sit for over 16 hours so I'm thinking thermostat...
And after sitting it has to be 10 degrees or colder for it to do it
What thermostat do you guys recommend for replacement?
Bump
Pelican parts?
