  4. E21 project thread
E21 project thread
233 Posts 19 Posters 0 Views 1 Watching
    Started calculating the angles and drawing up the jig in autocad. First I found the injector angle on the 318i fuel rail. I calculated it with a protractor to be 13 degrees. I then took a picture of the rail and drew up the angles in CAD and got 12 degrees. Pretty darn close. I decided to go with 12 degrees.
    From there I came up with a "simple" jig. The jig will be created from plywood. Two pieces connected at a 90 degree angle with bracing on the sides. The manifold will then be bolted to the vertical piece of plywood at the correct 12 degrees. This will allow me to place the entire assembly on the drill press and the holes will be the correct 12 degrees for the fuel rail. I used a generic manifold for the CAD model, so don't freak out too much.
    My thinking is this. First, I drill the holes to the fuel rail angle of 12 degrees. Then to get the correct angle for the injectors to fire fuel at the back of the valve as needed, I will then oval out the holes either with a boring bit or a dremel until the injector bung is sitting in correct position.
    OR, my other thinking was I could make the jig so that the outer braces are longer and have slotted holes. That way the entire vertical piece could be tilted backwards to the correct angle for the fuel to flow at the back of valve. This way in one movement of the drill press the holes will be at BOTH of the correct angles simultaneously. This will obviously take more fancy work with the jig. I am still debating which route I should take. Don't want to mess up my one and only intake manifold.
      #1  Nice idea on the jig.  that is pretty much what I had in mind also.
      #2  Use SolidWorks.
      #3 My vote still stands for "oval out the holes either with a dremel" after drilling.
      If you muff it up you can always just scrounge the internet for the next 10 years looking for another BAE intake manifold for sale. No big deal.
        Yeah cause that really helps my confidence in not screwing this up royally. Lol!
          don't worry, it's only permanent, like forever, all eternity, cannot be undone.
          you'll be fine
            More parts collected for the job. 318i fuel rail/fpr, 318i coolant neck to tap for coolant sensor, m50 tps, jeep idle air stepper motor, #24 injectors, and aluminum injector bosses to be welded in manifold.
            Also, time to make more adapters!
              I'm diggin' the progress Dave!
                Sweet!
                  so many custom parts. so many parts belonging to other cars.
                  so megasquirty.
                    Ok so I ran into fitment issues with the injectors and fuel rail with the manifold I have. Its just simply not going to work in the location normally used. After going through many many iterations on what I could do to make it work, I stumbled upon injectors from a 1.8t VW or Audi. They are considered EV12 injectors that are skinnier as well as having an extended tip on them. I found a used one on ebay for cheap to see if it would work with the CIS injector ports that are on my head.
                    CIS Injector
                    EV1 Injector
                    EV12 Injector (1.8t)
                    After fitting the EV12 injector in the head port exactly how I got, it seems to be a perfect length with the extended tip. The only issue is the headport hole being larger than the injector and o-ring causing the injector to not seal correctly.
                    To me it seems like if I could find a thicker o-ring with the same ID as the EV12, but a larger OD then I would be golden. Well, when comparing the two styles of injectors side-by-side I noticed that the EV1 injectors have thicker o-rings. BRILLIANT! I swapped the EV12 o-ring for an EV1 o-ring and BOOM! the injector now sits within the head port steady and seals well too. Now to get 3 more used ones or go for 4 new EV12 injectors.
                      Congrats=D
                        Science! Isn't it nice when things work out like that :)
                          I finished the adapters for the IAC and TPS today and got them mounted to the manifold. Vinyl cutter came in handy when cutting some gaskets for the sensors and throttle body. Mounted the throttle body adapter and throttle body to the manifold as well.
                          I also finished up some wiring on the megasquirt for the idle stepper valve control. Works great! Cant say that for the m50 TPS tho. The one I got turned out to be a dud after hooking it up to megasquirt and attempting the calibrate it. I opened the sensor up to find a broken wiper arm. Ggrrr! Time to search for a new one now.
                            Yesterday I removed all the CIS and K-jet turbo parts from the engine bay in prep for the EFI turo install.
                            Along with that I also removed the complete wiring harness. I will need to tear it apart and get rid of everything I wont need and integrate everything I will need into the MS harness.
                              Keep it up man.
                              Excited one day I may actually see it running in person
                              :P
                                its a lot of fun, I am really curious to see how the m50 swop compares to it
                                  Hells yeah!!
                                    Well, the 318i coolant neck has been drilled and tapped for the MS temp sensor along with getting cleaned and painted. The BOV also got a sprits of fresh paint (not the greatest, but no one will see it anyways, lol).
                                    a6544a10352465dd1602-01a7-41d9-93d3-2cb
                                    I also removed the Megajolt unit (which is for sale by the way)
                                    And I went ahead and tore apart the oem wiring harness. This was definitely an interesting thing to do. So much wiring was removed it shocked me.
                                    What was removed
                                    ef54a6a44c8bc3e4665e-b5c2-4235-8227-6ae
                                    What needs to stay
                                    8fe07c8cfc7b47d5fae8-312a-4e7b-9b38-243
                                      Looks like a ball of yarn in that first wiring pic. Should help to keep the bay clean!
                                        Did some more work today on the beem. I ended up cutting the grooves in the injectors for the clips to hold them to the rail.
                                        Fitted them in the head and found out the hard way that the FPR hit the head, not allowing the fuel rail to sit correctly. So, off came the FPR from the stock e30 318i fuel rail. I will be welding the hole shut on the rail and redrilling it on top of the rail in the same location as it was. Then, welding an injector boss (since the FPR has the same diameter o-ring as the injector) and the FPR mount in the new spot.
                                        After cutting the FPR mount off I fitted it to the head with the injectors and seems like it will be perfect. Until I put the intake manifold back on. :angry: The hose nipple that I was using for the feed to IAC interferes with the fuel rail, so off it came too. I jb welded it closed and will just need to smoothen it out inside the tb which isnt a big deal.
                                        So things are back on track once I get that fuel rail and FPR stuff welded and clean up throttle body. She's getting there!
                                          out of all the K-jet to EFI conversions I have seen, I like this one the best :D
                                          Driving Season 2014 will be epic
