  4. New ride! 89 e30 vert
summertime rage
141 Posts 18 Posters 1.6k Views 3 Watching
    Got me a new car, 7/88 325i/A
    Pros:
    Clean, no rust
    Sport seats
    Minty interior
    200$
    Cons:
    It's winter
    Auto
    Only drives backwards
      I love those front valances!
      • RamRod E28R
        RamRod E28R
        RamRod E28
        Ill race u backwards in my e28 mine only has reverse now too. Now to find u a manual to swap in there...
        1988 BMW 528e - Need parts?
        1996 Mazda Miata (SOLD!!!)
        1996 BMW 325i (Donor car)
          Is it factory?  And is it supposed to be white?  I wasn't sure, I hadn't seen one quite like that before, but I am not too familiar with all of the different e30's.
          Yes.  Does it drive reliably in reverse?  I need to get it a mile or two to a storage unit until spring.
            It is a factory valence. I usually see them body color but maybe it is to match your rockers
              Nice pick up!
              I have a manual drive shaft FYI
                I cant believe you got that for only 200!
                  best 'cons' list ever haha
                    DrLeadFoot said:
                    Nice pick up!
                    Excellent, I will be needing that.
                    Me either, went to Qwik Trip to get the cash out of the ATM.
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      I drove mine backwards for a mile and it was fine I it goes just push it... It's an e30 which probably can be pushed by the wind!!! lol
                        Awesome deal!
                          Factory build sheet, thanks to http://www.bmwarchiv.de/vin/
                          Modellbezeichnung: 325I
                          Ausführung: USA
                          Typschlüssel: BB23
                          E-Code: E30 ©
                          Karosserie: Cabriolet
                          Lenkung: links
                          Türen: 2
                          Motor: M20 - 2,50l (125kW)
                          Antrieb: Heckantrieb
                          Getriebe: automatisch
                          Außenfarbe: Alpinweiss 2 (218)
                          Innenraum: (0293)
                          Produktionsdatum: 16.07.1988
                          Optional Equipment
                          S219A: Sport leather steering wheel, 380 mm
                          S373A: Verdeck dunkel-blau
                          S530A: Air conditioning
                          S540A: Cruise control
                          S551A: On-board computer II with remote control
                          S675A: Sound System
                          S925A: Transport protection package
                            I pity the fool who has a BB23 Typschüssel, but at least your Modellbezeichnung is 325i
                            • mkoeppM
                              mkoeppM
                              mkoepp
                              Nice find! The tranny is an easy and cheap fix but if you plan a 5 speed swap I would not bother. Reverse will work all day long. I drove mine back roads home up north for over 5 miles.
                                Don't listen to him!
                                voteformanueldetailgrande.png?v=1373
                                  Don't worry, if it doesn't have three pedals it doesn't belong at my house.
                                    After waiting for 4 hours for a AAA tow truck to haul the car 3 miles... I got the car to it's home for the winter, nice storage unit 3 blocks from my house so when my e36 is out of the garage I will just drive it over here in reverse.
                                    As for the manual swap been doing a bit of research.  This seems to be a pretty easy job, this guy on e30tech made a great write up.  http://www.e30tech.com/forum/showthread.php?t=108141
                                    Any tips/recommendations from people who have done a swap before are welcome.  Out of curiosity who on here has done an auto to manual swap?
                                    I would like to use a lightweight flywheel and replace all chassis bushings with street poly ones but in the end this will probably get sold to my parents.  My dad would like a cool car to cruise around in now that the kids are moving out. so I will probably just use OEM bushings.  The writeup mentions using an e21 323 flywheel, it is identical to the "i" flywheel but less material on the engine side, 14.5 pounds instead of 18ish so I may go with that if I can find one for a decent price.
                                      I have done the swop.
                                      Let me be your guide.
                                       thumbswelcometotheinternetpleasefo
                                        Thatr is pretty cool.  Awesome deal.  Now Ramplesause will be longing for another convertible automatic.
                                          The Ireland Engineering street poly bushings are very streetable and much easier to install than OE rubber. You cant go wrong with OE rubber but you will just need a press to get them in.
                                          I would plan on removing the engine for the trans swap. It is very simple to do so and makes the swap 1000x easier. I had a stripped top bellhousing bolt and had to pull the whole thing anyways.
                                          Installing the pedals was by far the biggest hassle. Bassboy and I also discovered a very quick way to bleed a clutch for when you get to that point.
