  4. Savin Big Money Project Thread
should just dri
178 Posts 23 Posters 3.3k Views 3 Watching
    I do love the Arctic Grey, I haven't seen very many around.  I have way too much time/money into this car to let it go, I guess it's just an e36 but there are very few cars I would want instead.  Perfect blend of performance, great DD, and luxury.  I hope to have this car for a long long time.
      Well put.
      I saw the ever so lusted after Porsche 930 yesterday. I think they are neat, but the way my e30 drives and performs right now, I dont think im missing out on too much. I have bonded with the car to the point where I can throw it into any corner and dictate what I want it to do next.
      Seems like you are the same way with your vessel.
        In for the updates!
          What a beautiful thread title
            My name is John Menard.  Not related to the "real" John Menard though.  They won't give me any family discount even though I have spent thousands there...
            No updates for the car yet but I did get the wiring in my garage completed, 60A feed to sub panel, lots of lights and receptacles, even a nightlight.  Now its ready to get something done.
              Double post.
                Famous-characters-Troll-face-Cereal-Guy-
                  Got some work done last night.  After taking the belt off, the alternator sounds kinda scratchy when turning, anybody rebuilt one?
                  Found why I have to add coolant every month or so, upper rad hose connection was leaking a tiny bit.
                  Just buy OEM style hose clamps people.
                  One of these things is not like the other.
                  Here is where I am at now.
                  Piles of parts are growing.
                    Got the piles cleaned up and started taking some more parts off.\
                    Powered by Leinenkugels
                    And the persuaders.
                    Dropped the exhaust.
                    I haven't split the cat section from the catback ever but it sucks to take the full exhaust on and off so I just cut/snapped the bolts.
                    Test fit my 330 front brakes.  325mm
                    Just clears the 16" contours, as far as I know there are very few 16's that will clear 330 brakes.
                    From the back.
                    325 vs 330.
                    Removed front fenders, knuckles, struts, and control arms.
                    Here is how she sits now.
                    How does all this nast get into here??
                    Rust in here wasn't too bad, I expected worse.
                    These are still great after 45k on them.  Someday I may get something adjustable but not until these are worn out.
                    And my helper, she found the HG in the porch and was carrying it around.  She is also very helpful at sorting my sockets into the trash.
                      A pickle fork, bfh, AND Leiene's
                      a man after my own heart
                        I just love that Estwing drilling hammer, 3lbs of beatdown.  They should leave the word vanilla off of the name, almost didn't try it because of that lol, it is super tasty, I would highly recommend it.
                        • M318M
                          M318M
                          M318
                          The rust seems surprisingly controllable. How do you intend to keep it from coming back?
                              Your car looks like mine at the moment but your motor is in. There will be dirt in the frame behind where you had dirt before. No clue how I am getting it out.
                              • M318M
                                M318M
                                M318
                                Air then vacuum, repeat.
                                  My old wheels! Lookin good man!
                                    Haha exactly, I plan to cut out any bad parts and weld in new metal.  Parts with just surface rust I will use some rust killer stuff, and the whole bottom of the car will get POR15 or possibly rhino liner.  I don't winter drive it so hopefully after doing all of this it will be good for another 20 years.
                                    Inside of the rockers?  I think both sides will have some that needs to be cut and patched so I will be able to get a shop vac hose in there to clean it out.  I might cover over the holes where the plastic jacking pads went because I don't use them anyway and they are where the rust started from.
                                    Yep, I know there is dirt in there because I had the front end lifted up and if I tapped on the rockers sand/debris would fall out of the little drain holes.
                                    Yep, I like them a lot.  Probably will get some new tires next year, got these pretty well worn out.
                                      Finally an update:
                                      http://www.m5board.com/vbulletin/alpinaboard-com-bmw-alpina-discussion/141429-alpina-b3-3-0-e36-94-restoration.html
                                      This guy is crazy!  Also what do you guys think about the opposite of his original colors?  So I would paint black up to the plastic strips on the doors?
                                      Ok, there hasn't been any progress for a while because I have been redoing the plumbing and basement bathroom in our house.
                                      Out with the old, some of the pipes were so full of rust that there was only about 3/8ths inch diameter left.
                                      Bathroom
                                      On to the good stuff.  I got the engine and trans out.
                                      ABS, brake lines, fuel lines out.
                                      Gas tank, this was much more difficult than I thought it would be, once you undo the straps there are all of the evap hoses hooked onto the right front corner that are hard to reach.
                                      Dropped the whole rear subframe together, it balances perfectly with the jack under the differential pushed up against the hoop in the subframe.
                                      Kinda ran out of space, so I will have to disassemble it back here.
                                      I am ordering reinforcements and hopefully welding them in next week, the rust underneath isn't bad except the rockers.  Here's a couple of the tunnel and above the gas tank.
                                      Next things on the list:
                                      Disassemble rear suspension
                                      Remove brake booster and firewall insulation
                                      Cut unused brackets from engine bay
                                      Weld in new brackets for e30 coolant expansion tank
                                      Build some stands to support body while i repair the rockers, I will fab some stands to support it from the front sub frame attachment points and rear spring perches
                                        Do work!!
                                        • Q
                                          Q
                                          quick_shift95'
                                          Wow just read through this thread and I LOVE IT! Totally would've been this extensive with my car this summer if i had the time.
