  4. My winter bimmer 96 328i
winter bimmer 3
33 Posts 10 Posters 519 Views 1 Watching
  • M318M
    M318M
    M318
    I went to replace the post cat o2 when I discovered the o2 heated circuit power wire was cooked! Must have shorted on the chassis and just cooked itself.
    I followed it up all the way to the rats nest in the harness on the firewall!
    It was cooked like this all the way up to the little power wire junction crimp in the wire trough.
    I cut a nice long o2 sensor off of one of my other spare wire harnesses. It worked out pretty well so far. All in all it didn't really take that long and It wasn't really that hard. You just need a multimeter to find the wires because they cannot be removed from the rubber passage that brings the wires from under the intake up to the firewall trough.
      that last pic looks exactly like my wiring harness
      • M318M
        M318M
        M318
        Its a terrable mess when you crack that thing open! Look at the power wire! You would think it would cause interference due to EMI but whatever. I don't have alternator whine!
        • M318M
          M318M
          M318
          I have been busy this weekend.
            im overwhelmed. so much bmw in each picture.
            i wish i had a shop space!
            • M318M
              M318M
              M318
              Next thing is to install the entire new front end kit including control arms, sway links, inner and outer tie rod ends. Then its the rear trailing arm bushings.gallery332125699312.jpg
                I like it, the wheels almost look like steelies until you look close.
                • M318M
                  M318M
                  M318
                  I'm digging the bottle caps. They look much better dipped though.
                    I want!  Sweet winter ride!
                    • M318M
                      M318M
                      M318
                      I love the wet look.
                      • M318M
                        M318M
                        M318
                        I may have to sell this thing to pay for the M3 I am buying tomorrow!
                          more
                          bmw's
                          my god.........................................................................
                            GIVER!!!
                            • M318M
                              M318M
                              M318
                              I just got to finish up installing the other rear bushing, entire front end kit, vanos oil line, oil filter housing gasket and that should be good to go! I have more parts than time! ( I have all of the parts for this car, I just have a lack of friends that are motivated!) This thing runs really well. Anyway. If anyone one here wants this baby to help me pay off the M3, $2100 is a steal for this car considering that I personally went through it! I am very thorough and OCD when it comes to my cars!
                              • C
                                C
                                Celina325is
                                Damn, 2100, thats a steal all things considered
                                • M318M
                                  M318M
                                  M318
                                  Just fixed stereo wiring, some dumb kid must have run a speaker wire for each speaker. Bypassing the OEM amp like a dumbass. Now its back to awesome. Also I have finished the passenger rear trailing arm bushing and upper shock bushing. I Replaced the valve cover gasket last weekend and this weekend I did the vanos oil line and the oil filter housing bracket gasket.
                                  • BimmerBonezB
                                    BimmerBonezB
                                    BimmerBonez
                                    Nice work and thanks for documenting. Which M3 are you getting?
                                      This one.
                                      http://www.wibimmers.com/board/index.php?/topic/2087-97-m3-sedan-whole-car-rear-hit/#entry30867
