  4. My winter bimmer 96 328i
winter bimmer 3
33 Posts 10 Posters 519 Views 1 Watching
  • M318M
    M318M
    M318
    My winter beast is starting to shape up!
      M318 said:
      Just three E36's, Two '89 Toronado Trofeo's, One '98 Chrysler Frown & Cunty (300k) and one '05 Scion Xb.
      7 is quite a few haha, very interesting group of cars
      • M318M
        M318M
        M318
        Got her good and cleaned up. Time to get rid of those lame "Altezza style" taillight gayness!
        Before:
        During:
        After:
        • M318M
          M318M
          M318
          I was replacing the thermostat when I realized the clutch fan blades and clutch were shot. There was a crack in the shroud but not all the way through so I left it. I replaced the broken fan with a new fan clutch and fan that I had and it was fine until this happened:
          You just can't have anything nice. I think what happened was that the shroud gave way where that crack is allowing the fan blades to interfere. Now I removed it and need to figure out a nice way to wire up the a/c fan to a temp switch of some sort.
          • M318M
            M318M
            M318
            I went to replace the post cat o2 when I discovered the o2 heated circuit power wire was cooked! Must have shorted on the chassis and just cooked itself.
            I followed it up all the way to the rats nest in the harness on the firewall!
            It was cooked like this all the way up to the little power wire junction crimp in the wire trough.
            I cut a nice long o2 sensor off of one of my other spare wire harnesses. It worked out pretty well so far. All in all it didn't really take that long and It wasn't really that hard. You just need a multimeter to find the wires because they cannot be removed from the rubber passage that brings the wires from under the intake up to the firewall trough.
              that last pic looks exactly like my wiring harness
              • M318M
                M318M
                M318
                Its a terrable mess when you crack that thing open! Look at the power wire! You would think it would cause interference due to EMI but whatever. I don't have alternator whine!
                • M318M
                  M318M
                  M318
                  I have been busy this weekend.
                    im overwhelmed. so much bmw in each picture.
                    i wish i had a shop space!
                    • M318M
                      M318M
                      M318
                      Next thing is to install the entire new front end kit including control arms, sway links, inner and outer tie rod ends. Then its the rear trailing arm bushings.gallery332125699312.jpg
                        I like it, the wheels almost look like steelies until you look close.
                        • M318M
                          M318M
                          M318
                          I'm digging the bottle caps. They look much better dipped though.
                            I want!  Sweet winter ride!
                            • M318M
                              M318M
                              M318
                              I love the wet look.
                              • M318M
                                M318M
                                M318
                                I may have to sell this thing to pay for the M3 I am buying tomorrow!
                                  more
                                  bmw's
                                  my god.........................................................................
                                    GIVER!!!
                                    • M318M
                                      M318M
                                      M318
                                      I just got to finish up installing the other rear bushing, entire front end kit, vanos oil line, oil filter housing gasket and that should be good to go! I have more parts than time! ( I have all of the parts for this car, I just have a lack of friends that are motivated!) This thing runs really well. Anyway. If anyone one here wants this baby to help me pay off the M3, $2100 is a steal for this car considering that I personally went through it! I am very thorough and OCD when it comes to my cars!
                                      • C
                                        C
                                        Celina325is
                                        Damn, 2100, thats a steal all things considered
                                        • M318M
                                          M318M
                                          M318
                                          Just fixed stereo wiring, some dumb kid must have run a speaker wire for each speaker. Bypassing the OEM amp like a dumbass. Now its back to awesome. Also I have finished the passenger rear trailing arm bushing and upper shock bushing. I Replaced the valve cover gasket last weekend and this weekend I did the vanos oil line and the oil filter housing bracket gasket.
