  4. engine idle issue
engine idle issue
18 Posts 7 Posters 212 Views 1 Watching
    yes I do have it still.
    if you want to test your TPS , check continuity between two of the pins on the sensor (engine does not need to be on) and check for continuity with the throttle closed, it has been a while since I have messed around with them but I believe 2 and 18 have continuity at fully closed throttle  and pins 18 and 3 have continuity at fully open throttle.
    There is no need to remove the intake boot if you can manipulate the test leads like chopsticks and have good dexterity, but removing the intake boot is probably a good idea if its your first time so that you can see what you are working with.
    Make sure you test the switch multiple times. The last tps I had had continuity 6 out of 10 times I tested it.  There is also a tiny bit of adjustability in the TPS so if the continuity test fails you may need to remove the throttle body, loosen the mounting screws, and adjust the TPS so it makes contact.
      There is no need  remove the intake boot if you can manipulate the test leads like chopsticks and have good dexterity, but removing the intake boot is probably a good idea if its your first time so that you can see what you are working with.
      • 6670charger6
        6670charger6
        6670charger
        OK.  I'll have to look around for the thing tomorrow after I get up and see what I can find out.  Seems odd that I'd have a sudden huge vacuum leak, unless some hose somewhere suddenly ruptured in a big way.  Will also check the IACV.
        Read an article on IACV cleaning.  May sound like a stupid question, but, are throttle body cleaner and carb cleaner basically the same thing?   Sounds like they're pretty similar other than that carb cleaner may be a little more potent.
        Appleton, WI
          • 6670charger6
            6670charger6
            6670charger
            I take it that they're not the same?  I should be using TB cleaner?
            Appleton, WI
              My understanding is that TB Cleaner is not harsh on Teflon bushings or coated surfaces (anti-icing for throttle shafts) and carb cleaner is. I would probably use  Carb cleaner on it in a pinch.
                Carb cleaner isn't as harsh as everyone thinks. That shit evaporates so damn fast
                  makes it hard to huff
                    so does acetone. and it makes a spectacular fire starter
                    • 6670charger6
                      6670charger6
                      6670charger
                      Well, get this; After work I go out to start the car. Starts a little hard and runs a little rough for a few seconds, but then, straightens right out and ran fine all the way home.  Ran like normal yesterday too.  We'll see how she runs today.  Normal idle, and no problems with anything whatsoever.
                      I think I can rule out vacuum leaks and probably a clogged IACV.  Briefly considered that something might have briefly clogged the fuel filter, but, I doubt it would have started at all then.  Still wondering about the TPS, though.  Might be that it's working OK for now, but, could fail again at some point?
                      Appleton, WI
                      • JeffJ
                        JeffJ
                        Jeff
                        Does your oil smell like gas?
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                        • mkoeppM
                          mkoeppM
                          mkoepp
                          An ICV can act up and still work fine. I would clean in as a preventative measure if anything. My M20 did the same thing.
                          Good luck
                          • 6670charger6
                            6670charger6
                            6670charger
                            Sounds like a plan.
                            No, my oil does not smell like gas.
                            Appleton, WI
