  4. engine idle issue
engine idle issue
18 Posts 7 Posters 0 Views 1 Watching
    TPS?
    yes.
    http://www.wibimmers.com/board/index.php?/topic/2018-m20-tps-20/
    and vac leaks (check intake boot for tears) also check that the idle control valve is working
    • 6670charger6
      6670charger6
      6670charger
      Do you still have your TPS for sale Snap?
      Checked the car for start in neutral, and same thing, so it isn't the torque converter.  Basically won't run unless I have my foot planted on the gas constantly.  Will check the intake boot.  Found an article from Pelican on how to test the ICV and which vacuum hoses to test or replace.
      Just hope I can limp her home from DePere to Appleton tomorrow morning.
      Appleton, WI
      • JeffJ
        JeffJ
        Jeff
        Look into the iacv pull it off make sure it is clean. Usually when you have to hold the gas for the car to start it is the iacv or big vac leak
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          yes I do have it still.
          if you want to test your TPS , check continuity between two of the pins on the sensor (engine does not need to be on) and check for continuity with the throttle closed, it has been a while since I have messed around with them but I believe 2 and 18 have continuity at fully closed throttle  and pins 18 and 3 have continuity at fully open throttle.
          There is no need to remove the intake boot if you can manipulate the test leads like chopsticks and have good dexterity, but removing the intake boot is probably a good idea if its your first time so that you can see what you are working with.
          Make sure you test the switch multiple times. The last tps I had had continuity 6 out of 10 times I tested it.  There is also a tiny bit of adjustability in the TPS so if the continuity test fails you may need to remove the throttle body, loosen the mounting screws, and adjust the TPS so it makes contact.
            There is no need  remove the intake boot if you can manipulate the test leads like chopsticks and have good dexterity, but removing the intake boot is probably a good idea if its your first time so that you can see what you are working with.
            • 6670charger6
              6670charger6
              6670charger
              OK.  I'll have to look around for the thing tomorrow after I get up and see what I can find out.  Seems odd that I'd have a sudden huge vacuum leak, unless some hose somewhere suddenly ruptured in a big way.  Will also check the IACV.
              Read an article on IACV cleaning.  May sound like a stupid question, but, are throttle body cleaner and carb cleaner basically the same thing?   Sounds like they're pretty similar other than that carb cleaner may be a little more potent.
              Appleton, WI
                • 6670charger6
                  6670charger6
                  6670charger
                  I take it that they're not the same?  I should be using TB cleaner?
                  Appleton, WI
                    My understanding is that TB Cleaner is not harsh on Teflon bushings or coated surfaces (anti-icing for throttle shafts) and carb cleaner is. I would probably use  Carb cleaner on it in a pinch.
                      Carb cleaner isn't as harsh as everyone thinks. That shit evaporates so damn fast
                        makes it hard to huff
                          so does acetone. and it makes a spectacular fire starter
                          • 6670charger6
                            6670charger6
                            6670charger
                            Well, get this; After work I go out to start the car. Starts a little hard and runs a little rough for a few seconds, but then, straightens right out and ran fine all the way home.  Ran like normal yesterday too.  We'll see how she runs today.  Normal idle, and no problems with anything whatsoever.
                            I think I can rule out vacuum leaks and probably a clogged IACV.  Briefly considered that something might have briefly clogged the fuel filter, but, I doubt it would have started at all then.  Still wondering about the TPS, though.  Might be that it's working OK for now, but, could fail again at some point?
                            Appleton, WI
                            • JeffJ
                              JeffJ
                              Jeff
                              Does your oil smell like gas?
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                              • mkoeppM
                                mkoeppM
                                mkoepp
                                An ICV can act up and still work fine. I would clean in as a preventative measure if anything. My M20 did the same thing.
                                Good luck
                                • 6670charger6
                                  6670charger6
                                  6670charger
                                  Sounds like a plan.
                                  No, my oil does not smell like gas.
                                  Appleton, WI
