pistonse30
    ....Why are you putting in flexpiping..... this isn't a FWD car..
      I want to take any unnecessary stress off of the manifold.
        I guess. is your manifold top mount, an if so does it have reinforcements? Excessive heat and the weight of the turbo can make it droop over time, seen that happen a few times
            How have you liked the treehouse racing eyeball arms? Mine are arriving today=) Exhaust looks good btw!
              This whole build is just awesome, that exhaust looks great and I bet it sounds even better!
                I haven't had anything else so I guess I like them!
                Thanks!
                  Haha, Thanks!!!
                  He is finishing up today/tomorrow so I have no clue what it's going sound like.
                      looks proper!!!
                      I like it a lot
                      also, you should get an award or something.
                      for being basically the only member to finish their build on here!!!
                      :cool:
                        looks proper!!!
                        I like it a lot
                        :cool:
                        Thanks!!
                        I'll just take an award for getting out of that lot alive.
                        I'm not done yet! Just bought all my lines and connectors for the CCV and catch can set up. $360, ouch.
                          Done with a build??  I think that is somewhat like an exponential curve approaching infinity, it never actually gets there.
                            Can someone school me on which coolant temp sensor controls the ecu (blue?) and which goes to the cluster(black)? I have a brown top m20 single wire sensor but want to confirm.
                              looks proper!!!
                              I like it a lot
                              :cool:
                              Easy there killer! I should be on the road thursday!
                                Two Awards!!!!!
                                  Deadskittles
                                  Isn't 400 a bit low to shoot for with an s52?
                                    Sometimes 400hp is faster than 600hp. And besides Its not how you stand by your car, its how you race your car.
                                    As far as the coolant temp sensors, I believe blue is for the ECU and brown is for the cluster, but it has been a while so check to see how many wires each one has. I believe the ECU temp sensor has 2 wires and the gauge temp sensor has 1.  You will see that the harness is missing a pin when you disconnect it.
                                      My goal is to have 500+ to the wheels. The tune is the next hurtle I need to jump over. As of now I'm running über rich. After I get my CCV set up done I will tackle the tune.
                                      I do have 422 with a bad spark plug gap and bad tune... Plug gap fixed and she is pulling hard.
                                        I have a blue and a black sensor. Both are two pin. The blue is towards the front of the motor and and smaller diameter thread than the black one.
                                        These might be why I'm running rich. The black sensor top broke off while I was loosening it making me think it was on it's way out when I put down dat dyno run. Bad sensor thinking the motor is cold=fuel dump. I have to look into this. AHH!
                                          As of now I'm spinning a ton in 4th and a little in 5th. Both hands on the wheel and eyes up are a necessity. I just demolished a modded STi Friday night 3-5th to 130. #h3gon3
