  3. BMW Discussion
  4. Mitch's S52 M318 Swap
318 m3 swap eng
44 Posts 6 Posters 767 Views 1 Watching
  • M318M
    M318M
    M318
    MY BAD. I ordered the OEM M3 non sprung hub clutch with a single mass flywheel... I ain't down with chattering so I returned it... Now I am waiting on this...
    KF776-01.jpg?1329350881
    That dere is the E39 M5 Clutch and pressure plate. Looks like i am building it right. Probably wont even start.... anyway I spent way more than I planned but oh well whats money when it comes to your BMW!
      Exactly.
      • M318M
        M318M
        M318
        Did you know that on bimmerfest.com they were telling people to put their clutch disk in backwards to get rid of chattering. What do you think about that? Is it COMPLETELY ridiculous?
          As long as you install with a left handed wrench it should be fine.
          • M318M
            M318M
            M318
            so many projects, so little time.
            16335369large.jpg?v=1
            16335370large.jpg?v=1
              I know how that goes!
                It won't work lol. The flywheel bolts will run into the clutch disk.
                • M318M
                  M318M
                  M318
                  IM STUCK!!!! I just went to put my M5 Clutch KIT on.... The alignment pins do not line up!! I think I was supposed to buy the M5 clutch disk and not the pressure plate!?
                  • M318M
                    M318M
                    M318
                    What sucks more is that I already returned the M3 clutch disc and pressure plate.
                      Maybe someone else has more info but I think you are supposed to use an e34 m5 clutch.  I have the UUC flywheel with oem sachs m5 (which is a sprung hub) clutch and pressure plate but I think its for an e34.  Not sure if the UUC flywheel is different to accommodate the different clutch, I didn't try fitting the stock pressure plate over the dowels.
                      • M318M
                        M318M
                        M318
                        I have the E34 M5 clutch and pressure plate. I returned the stock OEM M3 kit. I am now thinking that I will have to use the M5 clutch disc and then buy the M3 Pressure plate! GRR and I went to put the exhaust on and I don't have any studs! God dammit this project is just one thing after the other. I feel like I am perpetually waiting for parts!
                          Oh earlier you said it was for an e39 m5.  Do you need studs for the manifold to head or manifold to downpipe?  If you can put the exhaust manifolds on the head before putting it in the car do it.  I found out it's very difficult to put the manifolds on with the engine in the car.
                          • M318M
                            M318M
                            M318
                            I now installed my M5 clutch with M3 pressure plate. They didn't send me a clutch alignment tool DAMMIT. Does anyone have a spare alignment tool?
                              I have one for an m50 w/ getrag, is it the same?  I could mail it to you.  Just let me know.
                                Should be the same since the trans are the same right. See if GunMetalGray has one, he is in the area.
                                  gsxify
                                  This is correct if you are using the E34 M5 clutch and you can use the E34 pressure plate. You need an aftermarket flywheel so you can flip the clutch so it will lay inside the flywheel. I'm not familiar with your flywheel at all.
                                  2c569698-d9c7-4c7d-95f2-e176a1893935zps
                                    Spelling!!!
                                    Do you have the smaller hole pilot bearing or the large one ?
