E28 rims
I have a set of e39 17" style 42's in the parts for sale section that would look great on a e28!
Here is the link.
Do they come with winter tires?
Earl is correct, you will just need hubcentric rings
Do you have the specs of the hubcentric rings I will need? Are the same as hub bore adapters?
OD should be 74.1mm, ID should be 72.56mm
I ran e39 wheels on my e36 (same hub size as e28) with a set of plastic ones off of ebay and they worked perfectly
Pm me and maybe we can work something out.
