  4. E28 rims
E28 rims
9 Posts 5 Posters 0 Views 1 Watching
  • mmradixM
    mmradixM
    mmradix
    I'm picking up a set of e39 rims to put on my e28. What adapters/ or spacers will I need? Tire size is 225/55r16.
      Are you getting some Style 5's or Style 19's? If so you will just need hubcentric rings and then the spacers are optional if you want to be hellaflush yo!
      • andyhundleyA
        andyhundleyA
        andyhundley
        I have a set of e39 17" style 42's in the parts for sale section that would look great on a e28!
        • mmradixM
          mmradixM
          mmradix
          Here is the link.
          http://chicago.craigslist.org/nwc/pts/4101781540.html
          • mmradixM
            mmradixM
            mmradix
            Do they come with winter tires?
              Earl is correct, you will just need hubcentric rings
              • mmradixM
                mmradixM
                mmradix
                Do you have the specs of the hubcentric rings I will need? Are the same as hub bore adapters?
                • Dominic540D
                  Dominic540D
                  Dominic540
                  OD should be 74.1mm, ID should be 72.56mm
                  I ran e39 wheels on my e36 (same hub size as e28) with a set of plastic ones off of ebay and they worked perfectly
                  • andyhundleyA
                    andyhundleyA
                    andyhundley
                    Pm me and maybe we can work something out.
