  3. New Member Introduction
  4. Yet ANOTHER Noob from Milwaukee -- Looking to replace suspension
50 Posts 11 Posters 971 Views 2 Watching
  • mkoeppM
    mkoeppM
    mkoepp
    I'll give you a hand at it also!
      How much are you looking at paying for shocks and stuts? I live in West Bend but the garage I have my car at is in Milwaukee=) There are defibitely flat spots to work on. Also, new shocks and struts would cause it to sit highers if yours are blown out at the moment.
      • X
        X
        xgeetx
        Mkoepp: I definitely appreciate the offer, but don't know that before Friday night is long enough! (But I don't really know how long this is supposed to take to do all 4 corners).
        Earl: I would say that ~$800 is my max, but lower is better... only because that'd be the cost of bilstein HD's + BavAuto springs (a recommendation from BimmerForums). I think that's a little excessive for my needs (daily driving). That's why I was also pricing out some Monroe shocks/struts/springs... but the consensus there is that they don't seem to last very long.
        After ordering some radiator components from FCPEuro, they are supposedly going to put together a suspension kit for me to take a look at that includes some Sachs struts/shocks... we'll see what the pricepoint is on that.
        Should I pick up a lift & jack stands or do you have some at your garage :)? What about that nifty BMW jack pad? Should I grab one of those?
          If your price point is that high then I definitely recommend Raceland Ultimos. http://www.racelandus.com/coilovers/bmw-coilover-kits/bmw-e36-ultimo-coilovers.html
          Even there normal kit isn't bad and it is $30 less. http://www.racelandus.com/coilovers/bmw-coilover-kits/bmw-e36-coilovers.html
          Shipping is also fair from them. I had Rokkors (basically stiffer normal Racelands) on my compact and drove them as low as they could go and my car rode way better than it did before changing my struts=)
          I have jacks, stands, and the tools to do it. No need for the jack pad. I have low profile jacks and your car is at stock height. I got this jacked up driving onto blocks and using a low profile so you will be just fine.
          • X
            X
            xgeetx
            Hmmm. Like I said, I don't have any interest in lowering my car, other than what the springs I purchase lower it. That being said, that strut/shocks/springs set is dirt cheap. Do the spring that comes with coilovers require any other springs? Why is this set so cheap? I don't see much information about what parts are in that kit, do you know the manufacturer of those struts/shocks/springs?
            My price point isn't really that high, that's an absolutely maximum... and would prefer something $300-$500... which puts these guys right in there. I've read that the bilsteins will take you far past 40k miles, do you know anything about these ones quality-wise? I also want to be careful not to change anything too much and then need to buy spring pads, or special tires/wheel spacers (I don't actually know when those are needed, just saying words)... Just want my car to ride really well :)
            On the topic of jack pads, PelicanParts made it sound like it's difficult to put the jack stands on after jacking it up, since the lift uses the same jack points. Do you jack from the front/back to do it then?
              Those are direct bolt in coilovers. Nothing else is required to install them. Raceland is the manufacturer. The Ultimos are higher quality than the normal ones. I had mine on for roughly 20k miles and I had them absolutely bottomed out. Neither one of them was blown when I removed them. I can see the Ultimos lasting you at least 40k miles, especially if you have them raised to stock height with helper springs installed.
              You won't need to buy new spring pads, tires, or spacers either. Spring pads are useless in my mind and I never ran them on my car, but these will not hurt them. You shouldn't run into any clearance issues between the tire and coilover since they are smaller in overall diameter than the stock struts with their large spring seat.
              The Raceland Ultimos would ride very well and handle good for what you are looking for.
              Also, you don't have to put jack stands under the jack pads. I actually look at that being very unsafe since they're so small. I usually put them on the lollipops in front and on the subframe mounts in the rear.
              • X
                X
                xgeetx
                Damn, I want to resist and not get coilovers simply because lowering isn't my priority... but they're so cheap! What all should I get along with them? I'm assuming that replacing my strut and shock mounts is necessary... anything else?
                Oh wait, what is that about helper springs? How much cost are those going to add? I imagine since my shock/struts and springs are worn out, my car is sitting a bit lower, and I like the look that it is... but I can figure out what I prefer later when these suckers are installed! Alright, so it sounds like I'll be picking between Raceland coilovers + helper springs, whatever kit FCPeuro puts up (Sachs), and Bilsteins + BavAuto springs (which say they lower it ~1 1/4")
                  Your front strut mounts should be fine but the rears should be done. I believe e46 convertible shock mounts are the good thing to get for the rear. I forget.
                  Helper springs come on the coilovers=) You don't need to purchase anything extra to install them. No need to resist coilovers because they are a great upgrade for the price. Down the road you may decide you want to go a tiny bit lower to make the car handle better (less body roll). I believe the Racelands will be your best idea for this.
                  • X
                    X
                    xgeetx
                    Do you find yourself needing to improve handling for daily driving? I guess my handling has never been an issue, even when my front end is bouncing through turns 😃
                    I agree they seem fantastically priced... I'm wondering if I don't EVER adjust my height (which I agree, I want it a bit lower than stock, but can get that with lowering springs like H&R), are they still a good value in terms of the quality of the shocks and struts? I just want to make sure I"m not paying for height adjustability, I want to be paying for quality shocks! I also want to be absolutely certain these will go on without a snap, no other modded components needed...
                    Thanks for all your help and patience!
                      Ten bucks says he eventually slams his car if he buys coilovers lol. But anyways, the racelands are going to be a huge improvement over your super blown struts, but they are still racelands.. Definitely get the ultimos if you do buy them. They really ride pretty decent.
                        You wont need to mod a single thing. They bolt right in. The Ultimos are great quality for what you are paying. They are perfect for what you are looking to do=)
                        • damnboy037D
                          damnboy037D
                          damnboy037
                          Welcome
                          Jack pads are ok, but pretty much useless.
                          99 M3 320rwhp @ 6psi
                          95 M3 s50b32
                          • X
                            X
                            xgeetx
                            Alright, Earl, I think you sold me. I've been doing some research and it sounds like they're great for a cheap set. I have one worry: speed bumps. It sounds like they have to lower at least 1"... how low before speed bumps start screwing up your car? I already have some torn pieces underneath my car (do I just get those welded, or just not car?), and don't want it to get much worse :).
                            I think I'd like to replace the mounts all around, since I'm pretty sure this car went 167k on one set of struts, it's probably best to swap out whatever is easy to do while we're in there! I imagine that means mounts & bump stops... anything else that's a good idea to pick up? Also, I can't believe the springs are so thin! The stock ones (at least on the back) are huge.
                              My e46 is lowered about 3.5" and have to go over speed bumps every day. You'll be fine.
                                Earl is right with the rear mounts. Go with e46 m3 convertible mounts.
                                  Bump stops are on the coils already too. I would just do mounts. I drove my car that I pictured over speed bumps so you will be just fine=D 1" lower than stock is probably where your blown struts have you at now
                                  • X
                                    X
                                    xgeetx
                                    Alright. Raceland's shipping is like $40??! Come on now! I'll be doing some last minute comparing this weekend to determine what I want to buy :). When would you be available to get together? Why do you have a garage in milwaukee? Are you going to murder me? What would you like for compensation :)?
                                    Why do i get e46 m3 convertible mounts for my e36 non-m? More durable? they'll still fit?
                                    Edit: I'm a little concerned about clearance after seeing this http://forums.bimmerforums.com/forum/showthread.php?1480398-Help-with-installing-coilovers
                                    Was he running non-stock tires? I'll get the numbers off the sides of my tires to be absolutely sure what I've got. Also, I don't see the bump stops on there... and I'd like to replace the stock ones, can you clarify how they're on there somehow? Also, what exactly is the difference between the helper springs and the normal springs? Sorry for all the questions, I really want to understand what's going in my car, and I don't see how these coilovers are equivalent to what I've been shopping for this whole time! I'm warming up to them though
                                    Thanks!
                                      The helper is supposedly to make the ride softer. I never run them. They sit above the normal spring. The bump stops are at the top in the front inside the top perch. The rear doesnt have them. The e46 convertible mounts are a direct bolt in and are stronger than the e36 mounts. Our stock mounts are prone for going up through where the shock bolts.
                                        Also, i never had clearance issues on stock tires.
                                        • X
                                          X
                                          xgeetx
                                          Sounds good. Well I'm doing my radiator tomorrow (got all the parts, woo!), so if that all goes well I'll put in an order for the Ultimos! Do you know if you actually have to jack the car up to bleed the radiator properly? My driveway is inclined, and there's a piece of cement that you have to bump over to get in the garage... I was thinking of just putting it there when I bleed the system. Thoughts?
                                          Thanks for all your help, I'm really glad you saved me $400 lol
                                          BTW: Based on the good old finger test, my back wheels currently have no clearance between them and the fender... I guess that means it's a little low? ha! The front I can fit ~3 fingers. I'm assuming it's because the back springs are broken, whereas the fronts are in tact.
