  4. 332ti, a compact story.
33 Posts 16 Posters 542 Views 3 Watching
    You know how I feel about this 😃 The mpg gauge doesnt work because the compact isn't wired for it. Just found the writeup for getting it wired in: http://forums.bimmerforums.com/forum/showthread.php?195537-Working-MPG-gauge-for-318ti-6-cylinder-conversions
    Also, the fuel gauge issue is most likely the sending unit-as stated below. It is a common issue. You can try resetting your computer to see if it is a glitch which also happens. Make sure you have the radio code in your owners manual before you do that though=P Another link for you: http://www.318ti.org/forum/showthread.php?t=3131
    Edit: You sent me this one last night so I figured I would let everyone get a taste of what you picked up=)
      Congrats, looks like a fun ride.  Fuel sender issue is probably one of them has an open spot in the potentiometer.  When the gauge drops to E pull the plugs off of both senders and check across with an ohmmeter.  One will probably show open.  I believe the senders are wired in series so one being open opens the whole loop.
        <- Jealous
        I would trade you cars.
        • AvusHatesConesA
          AvusHatesConesA
          AvusHatesCones
          Wow, looks like you got a great deal! Excited to see what you do with it
          Silver Grey E46 M3
            Congrats Alex! I have a Peake SRS tool if you'd like to check into that airbag light.
            • alexwA
              alexwA
              alexw
              Thanks guys,
              I'll take you up on that SRS tool too. I'll also be willing to let anyone help diagnose my wheel hop issue if they're coming to the 5er meet. ;)
              I'm pretty excited, headed to the DMV in a few to register it in a different county. My cluster is lit up like christmas. I'm sure the emissions folk would go to town on it.
              alexw
              332ti - Work in Progress
                Congrats! Looks like a really sweet car
                • alexwA
                  alexwA
                  alexw
                  Thanks again everyone!
                  I got the car registered today and listed it as being mostly driven in Langlade County, where I have family. That should make me exempt from emissions, shhh...
                  I sent the previous owner a email today about the wheel hop. I specifically asked if he had changed anything which produced an immediate issue, or if it just randomly started or progressed. Here's what he had to say:
                  someone said:
                  There seem to be multiple issues that can create similar symptoms. It was kind of the same when the flex disc (guibo) in the drive shaft was shot. That got progressively worse until I changed it. Then it was fine. Some time after that, the right rear shock tower / mount broke.(different, very obvious symptom) I fixed that with a reinforcement kit and installed those on both sides. I suspect the shock mount breaking may have caused a weakness in the rear bushings. Then when I started to get the current symptom, I inspected the rear dif mount and it was separating, so I replaced it. That didn’t fix it, next I replaced the center support bearing. That didn’t fix it. That’s when I replaced the drive shaft because the universal joint was not operating smoothly. It hasn’t really progressed.
                  So, because everything else back there has been changed, I think it’s the rear trailing arm / sub frame bushings. That would have been my next course of action. From what I could see, all the metal on the rear sub-frame and trailing arms looks pretty solid.
                  alexw
                    From everything he changed, I would assume axles, wheel bearings, or the trailing arm bushings. All of which a little tugging would help you find play and the issue.
                    • alexwA
                      alexwA
                      alexw
                      I just threw it up on jack stands. I let it run with the wheels free spinning and didn't hear anything. I tugged on the axels and wheels (for bearings) and it all seems solid. Im going to assume its the trailing arm bushings. I figure, I might as well try replacing the subframe and trailing arm bushings and see what happens from there.
                      IDK if it better describes the issue but-
                      I can drive the car without hearing the hop. I just have to not really lay into it. If you're just do and from work without smashing the throttle, its almost non existent. I can also lay off it and throw it into 3rd and run it all the way out and not feel anything. So what I'm getting at is, it seems to only "hop" when under hard acceleration and torque. I felt no such hop during my trip back home while I was in 5th and 4th, doing 65-90mph sprints.
                      Anyone?
                      alexw
                      • Ryan...R
                        Ryan...R
                        Ryan...
                        In4moarpics
                        • alexwA
                          alexwA
                          alexw
                          The car is pretty dirty. I'll take some photos tomorrow after I give it a wash.
                          alexw
                            cant wait to see pictures.
                            wheel hop on e30/e36ti rear suspension: sloppy/worn out suspension parts.
                            these cars are prone to it, though, and sometimes with new parts it doesnt go away entirely.
                            seriously, though, whats the point in spinning your tires in a straight line anyways? buy a muscle car for that.
                            • alexwA
                              alexwA
                              alexw
                              Well, it pretty much makes the engine useless to have if i cant put the power down. It happens if I turn a corner and gun it, same issue.
                              I'll give rides at the 5er meet, I'm sure we can figure it out. Im guessing you're right, its just going to be a matter of replacing worn bushings.
                              alexw
                                stickier tires and stiffer shocks can also help with the hop, if all else fails.
                                  Possible stupid question: does it have a welded diff?
                                  • alexwA
                                    alexwA
                                    alexw
                                    Earl, AndyHundley and I attempted to fix the issue last night. I suppose the issue is more of a driveshaft "slap". There are some photos somewhere that I may or may not upload but ultimately, we were unsuccessful.
                                    The center support bearing was completely shot. We all were pretty confident that installing a new center support bearing and the tranny mounts I bought would fix the issue. It did not. Here is my quote from the thread on 318ti.org http://www.318ti.org/forum/showthread.php?p=354506
                                    someone said:
                                    I had several caricon1.png savvy (and bmw nuts) ride and drive my vehicle. All signs pointed to a worn center support bearing. I went ahead and ordered OEM center support bearing and transmission mounts. Last night, a few friends got together and worked on my car. We found a completely shot center support bearing. The bearing was still securely on the driveshaft but the rubber around that was completely worn off, so basically the driveshaft was free floating in the center support bearing.
                                    We felt fairly confident that the new center support bearing would fix the issue, thinking perhaps the previous owner lied or installed it incorrectly. Unfortunately, this did NOT fix the driveshaft slap.
                                    Some things to note:
                                    - Driveshaft IS new. Still has stickers on it, it looks very fresh. I've sent an email to the previous owner asking for more details on it, i.e. install date, brand, etc.
                                    - Flexdisk or "Guibo" looks fine
                                    - I put the vehicle on jack stands and put it in gear and accelerated, I did not feel the shake. That being said, I didn't exactly beat on it while I was up there. So take that for what its worth.
                                    - While rotating the driveshaft, I noted only the passenger rear wheel was turning. I have receipts for a Limited Slip but have no idea what one is on there. Is that normal?
                                    - Fairly certain this isn't a rear subframe bushing issue. Under inspection they don't look that bad.
                                    - Engine Mounts look fine.
                                    Any advice would be greatly appreciated.
                                    alexw
                                      Its probably a Torsen LSD then.
                                      • alexwA
                                        alexwA
                                        alexw
                                        Last Saturday with the help of Chris and Andy, we fixed my car. This is a true story you may tell your grandchildren.
                                        Photos and long story to follow.
                                        alexw
                                          good to hear Alex
