  4. 1990 325ix no start???
11 Posts 4 Posters 114 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    well here is the scoop im lost a bit or over thinking this but the ix will not start.
    it has 155 compression on all 6 cylinders
    it has fuel
    it has spark
    what else am i missing?
    it does not even attempt to fire at all even at full throttle.
    crank sensor is at 520 ohm's and changes when cranking so its good.
    not sure what i am missing.
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • JeffJ
      JeffJ
      Jeff
      http://s1147.photobucket.com/user/ljx124/media/E3A64B92-891B-4F6E-A8F0-C33C35D8811F-927-000000F55F90E10C_zps514a4a4f.mp4.html
      a video to my problems
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        You say it has fuel, have you checked fuel pressure?
        My first suspects besides the crank position sensor would be the main ECU relay (aka DME relay) and the fuel pump relay. Those account for 2 of the 3 relays on the drivers side strut tower. Id listen and feel to see if they click when you switch the ignition on or jumper the pins on them to bypass them. A repair manual or the interweb should contain which pins need to be connected to bypass it.
        Also check the C191 connector for the fuel injection wiring harness on the drivers side of the engine, this one sometimes gets corroded and stops working.
        http://forums.bimmerforums.com/forum/showthread.php?1597051-C191-Multiplug-DIY-Repair
        it is a round connector that is a twist-lock like the O2 sensor connector is.   You may also listen with a stick or stethoscope to  hear if the injectors are firing while it is cranking to add some confirmation to whether the C191 connector is good or bad.
        • JeffJ
          JeffJ
          Jeff
          I used a fuel pressure tester i have 45psi i changed the relay also i will have to check the plug fir the injectors
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            thinking out loud here: If it has spark that means the crank position sensor is good.
            Injector wiring harness is definitely the next logical check
            • JeffJ
              JeffJ
              Jeff
              The pins look clean on the injector harness.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • JeffJ
                JeffJ
                Jeff
                Well guys my screw up i did not put the rotor on right. Hours of diagnosing and the ignition timing was off:/
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Glad it was a simple fix Jeff. Happens to the best of us=)
                    Ah, dont feel so bad Jeff, this guy did the exact same thing:  http://tinyurl.com/2g9mqh
                    • JeffJ
                      JeffJ
                      Jeff
                      ha wow
                      im doing 2 cars at the same working on the 325ix and a 72 mustang i have to strip and paint.
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                      • need4speed1299N
                        need4speed1299N
                        need4speed1299
                        For future reference, other than what was said here, I have a couple misc things to add. I have had my share of e30 m20 no starts.
                        1. If no crank, there is a wire that connects to the starter sometimes refered to as the "exciter" wire. Sometimes it gets corroded or loose. It has a 90* crimped connector on it.
                        2. There needs to be oil in the engine and the oil level sensor on the top of the oil pan needs to be plugged in. The car wont get an injector pulse.
                        3. Loose cap and rotor. Be careful with those bolts for the upper timing cover, they attach to the aluminum cylinder head. If they are loose, your going to missfire.
                        4. The crank position sensor and reference sensor connectors on the engine harness are very close and can be swapped accidentally.
                        5. Some years had an injector harness connector. This can get filled with corrosion and cause no injector pulse, but rare in my opinion.
                        6. Major vacuum leak.
