<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1990 325ix no start???]]></title><description><![CDATA[<p dir="auto">well here is the scoop im lost a bit or over thinking this but the ix will not start.</p>
<p dir="auto">it has 155 compression on all 6 cylinders </p>
<p dir="auto">it has fuel</p>
<p dir="auto">it has spark</p>
<p dir="auto">what else am i missing?</p>
<p dir="auto">it does not even attempt to fire at all even at full throttle.</p>
<p dir="auto">crank sensor is at 520 ohm's and changes when cranking so its good.</p>
<p dir="auto">not sure what i am missing.</p>
]]></description><link>https://wibimmers.com/topic/1889/1990-325ix-no-start</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:16 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1889.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Sep 2013 01:45:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1990 325ix no start??? on Mon, 23 Sep 2013 02:10:30 GMT]]></title><description><![CDATA[<p dir="auto">For future reference, other than what was said here, I have a couple misc things to add. I have had my share of e30 m20 no starts.</p>
<p dir="auto">1. If no crank, there is a wire that connects to the starter sometimes refered to as the "exciter" wire. Sometimes it gets corroded or loose. It has a 90* crimped connector on it.</p>
<p dir="auto">2. There needs to be oil in the engine and the oil level sensor on the top of the oil pan needs to be plugged in. The car wont get an injector pulse.</p>
<p dir="auto">3. Loose cap and rotor. Be careful with those bolts for the upper timing cover, they attach to the aluminum cylinder head. If they are loose, your going to missfire.</p>
<p dir="auto">4. The crank position sensor and reference sensor connectors on the engine harness are very close and can be swapped accidentally.</p>
<p dir="auto">5. Some years had an injector harness connector. This can get filled with corrosion and cause no injector pulse, but rare in my opinion.</p>
<p dir="auto">6. Major vacuum leak.</p>
]]></description><link>https://wibimmers.com/post/28301</link><guid isPermaLink="true">https://wibimmers.com/post/28301</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Mon, 23 Sep 2013 02:10:30 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Thu, 19 Sep 2013 02:10:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/28163">Snap said:</a></strong></p>
<p dir="auto">Ah, dont feel so bad Jeff, this guy did the exact same thing:  <a href="http://tinyurl.com/2g9mqh" rel="nofollow ugc">http://tinyurl.com/2g9mqh</a></p>
<p dir="auto">ha wow </p>
<p dir="auto">im doing 2 cars at the same working on the 325ix and a 72 mustang i have to strip and paint.</p>
]]></description><link>https://wibimmers.com/post/28166</link><guid isPermaLink="true">https://wibimmers.com/post/28166</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 19 Sep 2013 02:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Thu, 19 Sep 2013 01:20:37 GMT]]></title><description><![CDATA[<p dir="auto">Ah, dont feel so bad Jeff, this guy did the exact same thing:  <a href="http://tinyurl.com/2g9mqh" rel="nofollow ugc">http://tinyurl.com/2g9mqh</a></p>
]]></description><link>https://wibimmers.com/post/28163</link><guid isPermaLink="true">https://wibimmers.com/post/28163</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 19 Sep 2013 01:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Thu, 19 Sep 2013 00:26:16 GMT]]></title><description><![CDATA[<p dir="auto">Glad it was a simple fix Jeff. Happens to the best of us=)</p>
]]></description><link>https://wibimmers.com/post/28160</link><guid isPermaLink="true">https://wibimmers.com/post/28160</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 19 Sep 2013 00:26:16 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 20:15:18 GMT]]></title><description><![CDATA[<p dir="auto">Well guys my screw up i did not put the rotor on right. Hours of diagnosing and the ignition timing was off:/</p>
]]></description><link>https://wibimmers.com/post/28155</link><guid isPermaLink="true">https://wibimmers.com/post/28155</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 18 Sep 2013 20:15:18 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 16:16:50 GMT]]></title><description><![CDATA[<p dir="auto">The pins look clean on the injector harness.</p>
]]></description><link>https://wibimmers.com/post/28146</link><guid isPermaLink="true">https://wibimmers.com/post/28146</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 18 Sep 2013 16:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 13:05:05 GMT]]></title><description><![CDATA[<p dir="auto">thinking out loud here: If it has spark that means the crank position sensor is good. </p>
<p dir="auto">Injector wiring harness is definitely the next logical check</p>
]]></description><link>https://wibimmers.com/post/28140</link><guid isPermaLink="true">https://wibimmers.com/post/28140</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 18 Sep 2013 13:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 13:01:47 GMT]]></title><description><![CDATA[<p dir="auto">I used a fuel pressure tester i have 45psi i changed the relay also i will have to check the plug fir the injectors</p>
]]></description><link>https://wibimmers.com/post/28139</link><guid isPermaLink="true">https://wibimmers.com/post/28139</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 18 Sep 2013 13:01:47 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 12:24:36 GMT]]></title><description><![CDATA[<p dir="auto">You say it has fuel, have you checked fuel pressure?</p>
<p dir="auto">My first suspects besides the crank position sensor would be the main ECU relay (aka DME relay) and the fuel pump relay. Those account for 2 of the 3 relays on the drivers side strut tower. Id listen and feel to see if they click when you switch the ignition on or jumper the pins on them to bypass them. A repair manual or the interweb should contain which pins need to be connected to bypass it. </p>
<p dir="auto"><img src="http://blog.bavauto.com/wp-content/uploads/2010/04/RelaysECU-Fuel-E30E28-6001.jpg" alt="RelaysECU-Fuel-E30E28-6001.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Also check the C191 connector for the fuel injection wiring harness on the drivers side of the engine, this one sometimes gets corroded and stops working.</p>
<p dir="auto"><a href="http://forums.bimmerforums.com/forum/showthread.php?1597051-C191-Multiplug-DIY-Repair" rel="nofollow ugc">http://forums.bimmerforums.com/forum/showthread.php?1597051-C191-Multiplug-DIY-Repair</a></p>
<p dir="auto">it is a round connector that is a twist-lock like the O2 sensor connector is.   You may also listen with a stick or stethoscope to  hear if the injectors are firing while it is cranking to add some confirmation to whether the C191 connector is good or bad.</p>
]]></description><link>https://wibimmers.com/post/28135</link><guid isPermaLink="true">https://wibimmers.com/post/28135</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 18 Sep 2013 12:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to 1990 325ix no start??? on Wed, 18 Sep 2013 03:20:55 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://s1147.photobucket.com/user/ljx124/media/E3A64B92-891B-4F6E-A8F0-C33C35D8811F-927-000000F55F90E10C_zps514a4a4f.mp4.html" rel="nofollow ugc">http://s1147.photobucket.com/user/ljx124/media/E3A64B92-891B-4F6E-A8F0-C33C35D8811F-927-000000F55F90E10C_zps514a4a4f.mp4.html</a></p>
<p dir="auto">a video to my problems</p>
]]></description><link>https://wibimmers.com/post/28118</link><guid isPermaLink="true">https://wibimmers.com/post/28118</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 18 Sep 2013 03:20:55 GMT</pubDate></item></channel></rss>
