  4. e21 motor swap project
bmwe21big blockswap
87 Posts 19 Posters 1.8k Views 2 Watching
  • kyletime666K
    kyletime666K
    kyletime666
    Brian said:
    What size Pontiac motor is that?
    Stock it was 400 ci or 6.6 liters
      cant wait to see this running!
        Nice. I had a 6.7L 406 stroker, they definitely have the balls to move.
        • kyletime666K
          kyletime666K
          kyletime666
          The car will wiegh probably less than 2000 when done
          • kyletime666K
            kyletime666K
            kyletime666
            ok, sometime has gone by since my last update. alot of changes had been made. here are a few pics
            IMAG1279zps9fb78015.jpgIMAG1268zpsefe8d637.jpgIMAG1267zpsbf9bccae.jpgIMAG1262zps8849e502.jpgIMAG1256zps60521f3a.jpg
            Tube Chassis is done, motor is in, just finished all the wiring. Finally got my hand made rear end. Hopefully will have it mounted this weekend. its getting close.
              U N C R E D I B L E
              fabtastic work m8!!!
                Getting closer man! Keep up the amazing work!
                  Looks great Kyle! Chugging along...what are your plans for the interior?
                  • kyletime666K
                    kyletime666K
                    kyletime666
                    Two sparco seats, full carpet, back seats gone and all my electronics are in its place. Stock dash for now with digital dash in the stock location. Stock door cards.
                      Mad props man, mad props! This thing is gonna be immaculate by the time you're done.
                      • kyletime666K
                        kyletime666K
                        kyletime666
                        i had a slight freak out saturday morning and wasnt happy the direction i was taking.....so i dismantled the whole front end again and started over on the engine bay. In the 16 hours i put in this weekend i am 1000% happier with the results so far. it will be on the next level where i felt i was rushing and slacking before.
                          Dude!  Super sick!  Updates please!!!
                          • kyletime666K
                            kyletime666K
                            kyletime666
                              Very cool!
                              It is hard to pause, reevaluate, go backwards and keep moving forward.  Props!
                              I'm definitely in for more info on that engine and your current thought process!
                              • kyletime666K
                                kyletime666K
                                kyletime666
                                Thanks a lot man. Not much new with the engine at this point. 400 cubic inch big block with a decent build. Gonna run it that way for now. Really focusing on the chassis right now. I had one guy initially do the cage and frame and did a really shitty job. My friend chris Taylor took a look at it and has some wild ideas so I'm going forward with him. In the end I ultimately want it to be a very streetable race car. Depending how well the car reacts, next winter could see a more serious engine build and ALOT more power
                                  Awesome!  I'm excited to see the rear-end mounted up.  Are you thinking of tubing out the rear to fit some huge 300mm+ tires or flare out the fenders and go widetrack and stay with the Pontiac theme?
                                  Twin turbo big block!
                                  • kyletime666K
                                    kyletime666K
                                    kyletime666
                                    It is going to be beyond tubbed. No flaires though. We just built a motor similar to this and it made 800+ on the dyno all motor. Kinda wanna keep it n/a.
                                      Dayam! That's beefy
                                        Get this thing done!!! :D Haha! Cant wait to see this beast tear up some rubber.
                                          When are you working on this next?  I would be honored to see this in person or help out if you need someone to hold the flashlight.
