    Thanks guys;)
    • johnprusinskiJ
      johnprusinskiJ
      johnprusinski
      way to go earl. its coming together great.
        Thank you princess=) It's only from your motivation
        Got a few things done yesterday.
        The upper intake manifold and valve cover turned out great=) I love how simple they look shaved with the wrinkle black.
        I got curious as to how the hardware would look.
        I think I'll be leaving the washers raw instead of polishing them. I am so happy with how the motor is coming together.
        The bay also started getting welded up. My friend Jeremiah ran out of gas shortly after starting so he only got a few holes tacked shut. He will hopefully be back Saturday to continue=)
        I also just noticed that these pictures seem to look worse and worse. A new phone is needed and I will be picking one up shortly. A good camera is a must=D
        • JeffJ
          JeffJ
          Jeff
          looking great earl hurry and get "r" done
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            No rush=) I would rather get it done right the first time :cool:
            On a side note, welder couldn't make it Saturday and Lil Joe still hasn't gotten his roller back to do my fenders. Nothing got done this weekend at all
              Been a while since the last update.
              Zero progress on the welding and rear fender work. Trying to get all that sorted out.
              I am hopefully placing my order with Downstar this week for the hardware kit for my engine. I've just been sorting out what bolts will be able to use their beauty washers. Unfortunately there are three m7 bolts that they can't source because m7 is hard to come by=( I will try and figure that out.
              Yesterday I reorganized and cleaned my shop spot up. I also took pictures of things with my new phone because the camera is much better=)
              Enough talking, on to pics.
              Here is how far the bay got the other day before running out of gas.
              Hopefully this next week I quit dragging my ass and get this back in gear.
                This is looking awesome man, just went through your whole build. Keep up the hard work!
                  Thanks bud=) Lil Joe is working the rear fenders this weekend so lets hope everything picks up and starts moving steadily again
                    Finally a decent update.
                    I pulled up to the shop and saw this little guy.
                    I then walked inside to find this little guy
                    Then some work got done
                    After round one of tacking the seams
                    More to come Saturday
                      Looking good Earl, also, just to be safe, i'd put on a shit set of wheels, and not your expensive ones.. haha
                        Had that same thought. Just going to cover them with towels.
                          there you go
                            My rear fenders finally got worked over yesterday=)
                            Saturday was spent moving my stuff around yet again at the shop. I am thinking about relocating to a different shop that a friend of mine is moving into. I would have more space, running water, a toilet, and a small office.
                            Yesterday I smoothed out the welds for the holes in the bay.
                            A friend of mine was going over my welded seems and advised me to go a little different direction. Everything he said made total sense to me now and made me feel like a total idiot. According to him, all of these cold tacks have the opportunity to pop when force is applied. This would cause the filler to crack in that location. He also said that once I get it all cleaned back up, I should use a ball peen hammer to tighten the seems up. I don't know how that skipped my mind but now I know=)
                            Onto the fenders.
                            The drivers side went really smooth and just needs minimal bodywork. The passenger side is the one that had surface rust and that caused issues. The metal cracked at each end of the arch and once in the middle. This broke up the smoothness, but it will be an easy fix with a little massaging with a hammer and some sanding.
                            I am very surprised that the arches pulled this far. They are on the verge of as far as they can be pulled without cutting the inner fender. I need to do some slight trimming, heating, and bending of the rear bumper to get it to fit up just right, but that shouldn't be too big of an issue.
                            Alright, onto pictures.
                            The hard thing to try and fade out with the roller was the body line and it is still pretty visible. When the car goes for paint that will be smoothed out and transitioned cleanly. This is just a crude pull/roll to get the fender where it needs to be and to give it the general shape=)
                            I am still working on the engine hardware and am really shooting to get that wrapped up later this week, early next week. Now that the fenders are roughed out I should be able to get the fronts sitting right to match. I also need to solidify my air line routing and get my trunk setup mocked up.
                            Motivation is at an all time high finally.
                              Some before and after.
                                Needs more toe-in.... I see about an inch of space between your side skirts and the ground so im going to have to say that it also needs more low
                                  The toe in when you lower e30 rear suspension gets insane. I may be biting the bullet on having a set of adjustable trailing arms made by Dominant Engineering. That will calm things down a bit=P
                                    damn.
                                    nice work.
                                    :wub:
                                    do a burnout?
                                    • e92boostE
                                      e92boostE
                                      e92boost
                                      Sick work man! Can't wait to see the end result! What wheels are those exactly?
                                      Ben H.
                                        Theyre OZ Breytons. I imported them from Germany and then built them.
                                          My hardware situation has now been resolved. The order has been placed and now Frank at Downstar is just waiting for a few oddball sizes to arrive to ship them out to me=D
