  4. Flywheel Advise
Flywheel Advise
10 Posts 4 Posters 0 Views 1 Watching
  • M318M
    M318M
    M318
    Ok apparently I need to replace my dual mass flywheel every time a new clutch is installed says my bimmernut reputable mechanic buddy. I found this. What do you guys think? F1 RACING PROLITE 16 LBS FLYWHEEL http://www.allreplacement.com/product/1228
    I dont have time to fuck around either. I gotta order something quick. I am sick of pushing my car in and out of my shop.
      Go for it.
      Just steer clear of the blue flywheel of death
      dat s*** cray.
      • M318M
        M318M
        M318
        i ordered it already couldn't wait. Also can't spell advice.
        • AvusHatesConesA
          AvusHatesConesA
          AvusHatesCones
          Its a great flywheel, I have one on my e36 M3 and combined with light wheels, will make a dramatic difference!  . Just get an E34 M5 clutch to go with it to cut down on flywheel clatter. Also, for fluid, use 1  bottle of Redline 75W140NS gear oil and 1 bottle of Redline D4 synthetic ATF and you'll be good to go :cool:
          Silver Grey E46 M3
          • M318M
            M318M
            M318
            I just bought a brand new oem sachs clutch and pressure plate. Shouldn't I be ok with that? I got the 5spd zf also. So you are saying to mix those two fluids to put into my trans?
            • AvusHatesConesA
              AvusHatesConesA
              AvusHatesCones
              Yeah the OEM will be fine, the difference is the E34 M5 clutch is a sprung hub clutch, and that really helps cut down on clatter from the LTW flywheel. I 100% recommend that fluid combo! Made a big difference on my E36 for shift quality as well as killing a little of the flywheel noise.
              Silver Grey E46 M3
              • M318M
                M318M
                M318
                shit thanks for the info. Enterprise motorcars soaked me 35 bucks for a used oil container filled with bulk diff fluid for my 318 trans lol. I can imagine what they would do to me if I asked them for trans oil...
                  Go for it.
                  dat shit cray.
                  Are you referring to the UUC one?  Whats the stinky on that?  Just curious as I have had one for a few years with no troubles.
                  Also the mixture of redline fluids is excellent, I have no gear rattle after putting that in with (e34 M5 clutch)
                    I dont think its actually been proven, but the rumor is that the lighter flywheel and increased rev limit has caused some bad harmonics resulting in catastrophic engine failure.
                      Oh, I am still using stock tune.  Is the UUC one worse than others?  I think a bigger issue is the super smart folks replacing the harmonic balancer with a under drive pulley.  I'm sure the flywheel is important but the harmonic balancer is what keeps the crank in one piece.
