  4. Anyone done an OBD2 into OBD2 Swap?
14 Posts 5 Posters 0 Views 1 Watching
    Wut?
    Aren't the m42/44's obd1 anyway?
    Advice is pretty broad. I would suggest to not do it wrong.
    But in a more serious note what are you looking for help on?
      M42 is obd1 and m44 is the lamer obd2 counterpart;) Swap should be straight forward.
      • M318M
        M318M
        M318
        my m44 was obd2 all 96 and up vehicles are obd2. I just want to install my obd2 s52 and keep it obd2. Its a PITA to convert to obd1. Also a PITA to keep it OBD2 because of the EWS2 system. My DME is not going to recogonize the EWS2 chip in my key that I have because the DME looks for a specific code. :( I believe that i am in for trouble. Im going to put the motor in this week and worry about that shit when the time comes to start it. I found a place that can remove my EWS2 system in my DME by reflashing it and it costs around 400 dollars :(
        • M318M
          M318M
          M318
          So basically I was wondering if someone else has a S52 in their 96 and up vehicle and kept it OBD2 and how they did it. All of the builds I have read about were talking about doing the OBD1 conversion. It is pretty frustrating. I could buy an M3 but my car is the cleanest I have ever seen in my body style, without a speck of rust anywhere on the vehicle ( I check it constantly and clean under gaskets and ext.)
          • M318M
            M318M
            M318
            How is the M44 lamer? It has a sweet .1 liter increase in displacement and you loose the lame clutch fan?
            • JeffJ
              JeffJ
              Jeff
              Get the ews system re aligned or remove it.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                It made less torque and my m42 has/came with an electric fan.
                  M45 triple vanos or go home.
                  • JeffJ
                    JeffJ
                    Jeff
                    this^
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • M318M
                      M318M
                      M318
                      I found this amazing forum. It has everything ya need to know.
                      http://www.r3vlimited.com/board/showthread.php?t=266738
                      Now I feel much better about my project.
                        r3v is a good place. make sure you have thick skin.
                        • M318M
                          M318M
                          M318
                          I don't talk on there just read. Too many ignorant fools from cali that think they know everything.
                          • M318M
                            M318M
                            M318
                            Good christ you are right. Bimmerfest guys are fucking cynical dousche bags! Give bimmer drivers a bad name! You would think you are on a MERCEDES forum!!!!
