My 1992 318is, I guess you could call it a build thread
so we aren't friends then
Nobody said we weren't friends!
When you put the plastic skirts on do the jacking holes line up with the ones in the body? I have a 94 and might put some on. Just curious because bavauto sells some plastic skirts but warns that the holes will not line up.
They do, mine lined up perfectly. I don't know why they told you otherwise. The post 95 cars that came with the skirts from the factory are the same underneath, they just have holes drilled into the body to mount the skirts. My skirts are OEM so there might be a difference if the bavauto ones are aftermarket so I would ask why they say that
Great to know, thanks! Mine has some rust to be repaired n the rockers and if it doesn't look great (new to bodywork) I am going to just put plastic skirts on. I like the two tone early e36 style and will be keeping that as well, it's not as noticeable on mine though being arctic gray.
After much deliberation this past weekend, I think I may be putting my car up for sale. I will being going over the e30 tonight to make my final decision but I've seen the car many times before and I am pretty sure I know how this is all going to turn out. Would anyone be potentially interested in it? I will probably write up an ad but for the time being I think this thread gives a pretty good overview. If I do sell it I'd really like it to go to an enthusiast
How much will you be asking for it?
I had it advertised for about 2900 last summer without the 17's and with a few problems that I have since corrected and I had a bit of interest but I decided to keep it. Since then I have done a decent amount of maintenance and improvements. There really aren't many 318's around in good shape for sale so I don't know If I am being reasonable or total pie in the sky when I say maybe $3500 (asking price) with everything including all the extra parts/sets of wheels/bentley manual/etc. I am definitely willing to negotiate as I would rather it go to a good home. I am unsure as of right now if I will actually sell it, but I will try and make a decision this week.
I've done a bit of looking around and the 3500 number seems a bit high. I am putting up an ad for the car on craigslist and I am asking $3300 but there is definitely some wiggle room, especially if it goes to an enthusiast like you guys. Here is the ad:
http://milwaukee.craigslist.org/cto/3942623212.html
But for you lazy folk I'll paste the text:
1992 BMW 318is
2-door coupe, E36 body style
- 1.8L Inline 4, 5 speed manual transmission
- 165xxx miles
- Sterling Silver Metallic/Clear Coat paint
- Gray cloth interior
- Pass through rear seats
- Original engine/transmission/differential
- Oil Changed every 3,000miles/6months
- FULL service history from my ownership, some records from previous owners
- Body is solid with no serious rust
- Regularly average 30+ mpg per tank
- Interior 9/10
- Exterior 7/10
- Extremely reliable
- Enthusiast ownedI had no intentions of selling this car for a long time but I am buying another bimmer and do not have the space for two. I have invested well over 2k in parts to make this car as perfect as possible and I have saved every receipt and invoice. It is a very good candidate for a swap as well.
Maintenance in the last 2 years/20k miles (In no particular order, possibly forgetting something as well):
- Power Steering return line
- Trans ouput seal
- Flex disk/guibo
- Oil Pan gasket
- Shift shaft input seal
- Both differential output seals
- Both front control arms (inner and outer ball joints), replaced with Meyle HD with solid metal ball joints
- Powerflex street polyurethane front control arm bushings
- Radiator
- Water Pump (with cast metal impeller)
- Thermostat
- Upper and lower radiator hose
- Expansion tank
- Fan clutch
- Fresh BMW coolant
- All cooling system gaskets
- All 3 belts on front of motor
- intake boot
- Bosch spark plugs
- New Fog light bulbs
- Air Filter
- Cabin air filter
- Powerflex rear trailing arm bushings
- Rear shock mounts (Meyle HD upgraded mounts)
- Rear shock mount reinforcements
- Oil changed every 3,000 miles/6 months with Castrol GTX (filter replaced every time)
- Clutch slave cylinder
- Fuel line between hard line and motorParts included but not installed
- Rear brake dust shields (left and right)
- Parking brake springs and hardware
- Reverse Light switch
- Rear 3.45 differential (open) with less than 100k
- Two output shafts with less than 100k
- Set of 4 near perfect 15" BMW bottle cap wheels with old tiresUpgrades:
- Solid metal ball joints in front control arms
- Heavy duty rear shock mounts and reinforcement plates
- Polyurethane rear trailing arm bushings
- Polyurethane front control arm bushings
- 17 inch Mille Miglia MM-11 wheels with low profile tires
- Memphis Audio 3-way 6x9 rear speakers (rear decklid adapters so they are hidden, no cutting for install)
- Pioneer tweeters
- Alpine Head unit
- Headliner recovered in matching gray suede as well as door panel inserts
- Custom door panels (I have the originals, they just need to be refurbished)All parts installed are either BMW or other OEM equivalent
Cons:
- Needs a windshield
- AC does not work, may only need a rechargeI also have a set of four Blizzak snow tires on 15 inch steel wheels that I could include for a bit extra since they need to be shipped from Pennsylvania.
I am asking $3300 but am willing to negotiate
Please email or call or text 414-7zero4-00two5 for any questions or picture requests
What do you guys think? Any input is appreciated
Well guys, its the end of an era for me, the car is sold and gone. I got what I wanted for it and the new owner is very happy and will take great care of it. I was sad to see it go considering how much work I've put into it but its on to my new project, I can't wait for the day when my new e30 is as nice as this car!
