  3. BMW Discussion
  4. Help painting trim
Help painting trim
16 Posts 7 Posters 185 Views 1 Watching
  • 0
    00A
    Do you know if they have it in matte black by chance? I want to sand them smooth and have them in a smooth matte black.
      Just buy new trim. They're cheap and it'll hold up much better. I've used the trim paint on e46 bumper trim on a car at work. I was relatively unhappy with it turning out slightly more glossy.
        RaulsRR
        ^^ True it is a bit of a semi gloss. I've done all trim pieces before and it turned out decent. Any matte flexible acrylic paint should also work. If you don't like the result spray them again or go with all new trim.
        • 0
          00A
          I saw on another forum people were just sanding them smooth and using 3M vinyl wrap.
            You could vinyl wrap it. Don't see why that'd be an issue!
            • 0
              00A
              I was actually thinking of doing that.
              • J
                J
                jafza412
                +1 for wrapping. I wrapped mine and it was way easier than painting. No need to sand either, just make sure it's clean.
                  Jamil does a decent job of wrapping parts as well. He wrapped a few of his interior peices on his E92!
                  • L
                    L
                    Laishes
                    Back when I had my civic I plasti-dipped my trim and it turned out very good.
                    • 0
                      00A
                      I want something a bit more lasting than plastidip
                        Vinyl....
                          Also, plasti-dip is pretty lasting. Clean the surface, and spray. It's stupid easy, and is durable.
                          • 0
                            00A
                            Plastidip is a lot harder to get a really smooth surface. A lot of time there is still some roughness to it. I think I'm going to order some vinyl when I get home.
                            • I
                              I
                              industrialsized
                              i have had good luck sandblasting and useing very light coats of spray on truckbed liner
