  3. BMW Discussion
  4. Help painting trim
Help painting trim
16 Posts 7 Posters 186 Views 1 Watching
  • 0
    00A
    Hey guys,
    I want to paint the trim in my bumpers and doors on my e46. I'm just wondering the best steps to take when painting it since it's a flexible polyurethane.
      RaulsRR
      I always have used SEM- trim black paint. Body shop supply on greenway cross in madison carries it.
      Scuff up the piece a bit with a scotch-brite pad and clean it off with rubbing alcohol or something of the sort then spray with a few light coats.
      • 0
        00A
        Do you know if they have it in matte black by chance? I want to sand them smooth and have them in a smooth matte black.
          Just buy new trim. They're cheap and it'll hold up much better. I've used the trim paint on e46 bumper trim on a car at work. I was relatively unhappy with it turning out slightly more glossy.
            RaulsRR
            ^^ True it is a bit of a semi gloss. I've done all trim pieces before and it turned out decent. Any matte flexible acrylic paint should also work. If you don't like the result spray them again or go with all new trim.
            • 0
              00A
              I saw on another forum people were just sanding them smooth and using 3M vinyl wrap.
                You could vinyl wrap it. Don't see why that'd be an issue!
                • 0
                  00A
                  I was actually thinking of doing that.
                  • J
                    J
                    jafza412
                    +1 for wrapping. I wrapped mine and it was way easier than painting. No need to sand either, just make sure it's clean.
                      Jamil does a decent job of wrapping parts as well. He wrapped a few of his interior peices on his E92!
                      • L
                        L
                        Laishes
                        Back when I had my civic I plasti-dipped my trim and it turned out very good.
                        • 0
                          00A
                          I want something a bit more lasting than plastidip
                            Vinyl....
                              Also, plasti-dip is pretty lasting. Clean the surface, and spray. It's stupid easy, and is durable.
                              • 0
                                00A
                                Plastidip is a lot harder to get a really smooth surface. A lot of time there is still some roughness to it. I think I'm going to order some vinyl when I get home.
                                • I
                                  I
                                  industrialsized
                                  i have had good luck sandblasting and useing very light coats of spray on truckbed liner
                                  With your input, this post could be even better đź’—
