    It won't once it gets painted=) Tractor paint is going on soon.
      Those wheels look amazing, cant wait to see them on the car!
        You and I both. Once I seal them I can get the tires mounted. Then I will be fitting them to the car.
          I got around to seling the wheels last night.
          I bought this:
          And then did this:
          I will put another bead on when I get home and then they'll be ready to wrap in rubber=)
              I got the tires mounted yesterday. McAdams did a great job without any damage to the wheels. The stretch is perfect for how I need the wheels to fit.
              Front (17x9.5 w/ 205/40 Hankook HRII)
              Rear (17x10 w/ 215/40 Hankook HRII)
              My rear subframe isn't in, but I wanted to get an idea on how the wheels will sit in the rear. They will be a little more aggressive, so the wheels will come out more. This gives an idea of how it will look though.
              I'm very happy with how it is coming together=) Hopefully I can get the subframe bolted up on Saturday. No need to run brake lines now since I'm running out of time. That can be done on the car later.
                Not a fan of the stretched tire, but that is a nice looking press!
                  The tire stretch will be a bit much for most people here, but it is neccessary for me to achieve the fitment I'm going for=)
                  Good thing I'm not one of those people who cares what other people think about their car :)  This car is being built by me, for me=D I give no shits if anyone else likes how it looks.
                  I mean, who builds their car just to impress other people? That's just dumb
                  Not going off on you Robert. I just wanted to state I'm not doing any of this for scene point or to impress anyone. I'm just building it to make myself happy and screw what anyone else thinks. However, I do enjoy when people say good job and such=)
                    I compltely understand where you are coming from, and even the 'why' behind it.  I love seeing other peoples stuff, if it was all the same it would be boring.  Some of it I'll like, some of it I won't.
                    Regardless, all the work you are putting into your beast is impressive, and I love the updates.
                      Thank you sir=) You get exactly what I'm saying=D
                        Looking good earl.
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          I love it.  You'll be on StanceWorkZzZzZ in no time.
                            Picked up these guys Friday night:
                            97' Mustang GT shocks. $60 from Autozone. Lifetime warranty=D
                            Reason for choosing them:
                            I was going to measure them, but forgot to before I installed them. The mustang shocks are shorter by about 1.5" when extended. The strut body is also shorter and has more stroke. This will give me more suspension travel and let me go more than low enough.
                            I also got this guy finally installed.
                            Things are finally coming together.
                            Yesterday morning I ordered a 68mm stud kit from Motorsport Hardware. They shipped last night and I cannot wait for them to arrive so they can go straight on.
                            Stay tuned.
                              Anderson-Cooper-Popcorn-Gif-While-Live-O
                              love it Earl.keep us posted!
                                Haha thank you sir:)
                                I had a chance to stop by the shop for a bit today. I was going to mount the bags to the top, but I grabbed the wrong bolts from work. I'm also not sure how I will be measuring to get the holes in the right locations. I did get a chance to actually mount a wheel up and jack it into place to see how much work is needed. If I could adjust camber I would have no issues, but unfortunately camber cannot be adjusted. So a slight pull will solve my issue.
                                  I managed to get nothing done yesterday. I was figuring out how to mount the top of the bag but couldn't find the right tools/bits to use. A package came however:
                                  My airline also arrived today. I'll mount the bags Saturday as well as install the studs and hopefully a bunch more.
                                    this is how I feel everyday after I punch out.
                                      I am very pleased with the outcome of Saturday=)
                                      I finally got the top of my bags mounted. The first side took two hours....the second side only took about 30-45 minutes. Here is what I did (before paint of course)
                                      There is one bolt up top and then a notch underneath for the fitting to sit in. The pockets were the biggest pain to get. The first one took so long because I was trying to use a countersink bit and other drill bits. Then I realized I had air tools that would make it a whole lot easier=)
                                      Once that was finally out of the way, I bolted up my sway bar and bolted the bottom of the mustang shocks to the trailing arms. Everything went super smooth there.
                                      I then installed my 68mm Motorsport Hardware studs. I am super happy with the quality of them. Installation was a breeze and I highly recommend them to anyone who wants to go studs versus lug bolts. The price tag for these is basically just giving them away=D
                                      I also painted the hats of my rear rotors during this time, but did not take a picture. I will be getting new rotors this winter, so this is just to make them look less shitty until then.
                                      After all of this I cut air line for the bags, pushed on some valve stem fittings, and manually aired up the bags. I put the rear wheels on and put it back on all fours for the first time since February. I then aired it out.
                                      I was being goofy. I actually have to do way less fender work than I had initially thought. That's fine by me=) I just need to get the fenders over the tire, but let the lip still poke. Right now it is literally sitting on the tire. Here are a few more of the wheels and being aired out on the Breytons.
                                      I am finally seeing things come together and it is awesome=) The studs poke a tiny bit much for me, but they were the shortest I could get being black and bullet nosed. I think they will still keep the clean and subtle look without being too aggressive.
                                      On a side note, my friend Kerry has been working on my rear bumper and I cannot thank him enough. I wanted the exhaust cutout shaved so I can have the exhaust hidden underneath. I am not a huge fan of DTM tips and this was the cleanest option I could come up with. I also don't really like the M-Tech rear bumper so I figured I would make the OEM one better.
                                      He did such an excellent job. He used no bondo and uses only the finest plastic repair kits. Bravo Kerry=)
                                      More to come Wednesday. Maybe I will take a funny picture of how the rear is sitting right now aired out on stock wheels.
                                        You are doing a great job on this Earl
                                          Thank you Brian=) Your approval makes it all worth it
