pistonse30
    The bottom end is at the machine shop. pistons and rods should be coming this week. Ordered a MLS gasket in the OEM width.
    Sent from my SCH-I535 using Tapatalk 2
      The crank bolt was a pain.
        What did you use to clean up your timing cover? It looks so smooth=D
          I media blasted it and two coats of primer.  She is smooth!
            You weren't afraid of particulate getting stuck in the cover and contaminating the oil? Maybe I'm thinking too much=P
              I will clean the crap out of everything when I'm putting it back together. e5a3y9a7.jpgy6uneduq.jpg
              Still waiting on the rods and pistons. They were to be shipped this week. Maybe today...
                Looking good!
                  Pistons are coming Friday and rods Wednesday!  Time to get crackin!
                  • T
                    T
                    tsweers89
                    2 things, well more than that but I'll just list the main things. 1. what the fuck were you thinking painting things gold. Like really?? 2. You are building the motor why did you not o-ring the block and use a oem headgasket or CES cutring gasket? This is the way to go if you did research!!!!
                      Oh, Timmy. Take a deep breath.
                      Monday is go day!! My crank is being polished now and is looking a-ok!
                        Ready for pistons! Rotating assembly is being balanced now.
                          Are the indvidual pieces being balanced by themselves or is the harmonic damper, crank, flywheel, and clutch assy. being balanced as a unit?
                            Bmw made a 5 cylinder?
                            Trololololo
                              Crank rods and piston are getting balanced as a unit.
                                Trololololo
                                Volvo swap!
                                • T
                                  T
                                  tsweers89
                                  What are you doing with the head? Might as well build it to.
                                    It's already fully rebuilt and I polished the exhaust ports. Stock everything else. Just paid for my GOLD powdercoated valve cover!
                                          Got new flares I see. Are they the Kamotors ones? You had ones molded in before right?
                                          Digging the progress=)
