problem?
Why are the quotes times different than your post time? Look at every quote, and then its original post. WOAH!!!
That quote above is trippy. It says I replied to the quote at 9:26, but Brians post is said to have happened at 9:28...
Dude stop.... I cant even...
Yes you can. Rotiform can custom make you lips for any wheel. idk.
I really hate slant lips, or the lips that'll take you from, example a 15" rim to a "16inch" rim by making the lips 1" or whatever amount taller.
But slant lips seriously look god awful in my opionion.
Rotiform makes shit product. If I wanted cracked lips I would have kept my old ones and ran them over a few times. Plus they charge way more than I paid. Each one of their lips costs at least twice as much as my lips.
Slant lips can look good on certain cars and face styles. I don't like huge slants, like the 16" to 18" ones for RS's, but a 1" slant can look classy. However, Mexican car was very sexy on his RS's (that's the e36 you posted). They didn't look lippy, but they complimented the car well.
I like stepped lips because they are more complicated than a blah flat lip. They add depth and I like how the light hits off of the stepped portion. It just makes the lip seem more aggressive.
Brian, on 17 May 2013 - 12:17, said:
I didn't post Mexican's E36, I posted Jaycee's WRX lol, unless you're talking about a further back post?
Ope sorry. I forgot Mexican had red bbs caps. I didn't look at the front bumper in the picture. I'm not a fan at all of how that WRX looks. It doesn't look feature worthy to me.
I did like Mexicans car still though=)
I agree with you on your reasons for likeing stepped lipes, and your clain that flat lips look blah and cheap. However I still choose flat lips as they make the wheel look bigger and deeper. Seems like you're just cheating the sidewall with stepped lips. I used to have real BBS LM's and the stepped lipe was the one thing I didn't like about them.
Meaning the stepped lip allows the same center that would have been used on an 18" rim with flat lip, to be used on a 19" rim with a stepped lip. Mostely semantics, I just like the largest lip and largest center I can get in my wheel size
Cool (to me):
Uncool:
I get what you're saying oe Robert. I agree up until a certain width lip. 1" to 2" stepped lips don't look at good as 1" to 2" stepped lips to me. 2.5" stepped lips on up look good to me because they have depth, and it evens out the amount of lip to face size. With my 3.5" lips, there is at least 2" of flat lip before the step. They then have a 1" step to another 1" flat:) To me that looks better than 4" of flat lip.
Small updates from Saturday. I had the barrels bead blasted on Thursday so I figured I would paint them. I used Tractor and Implement paint from Fleet Farm. It lays really nice and is pretty durable.
I missed a few spots and ran out of paint. I'll be touching that up tonight. I also noticed that two barrels have a few flat spots in the lips=( Looks like I'll be going wider out back this coming winter.
After that I decided to reinstall my RTAB's properly. I had the sleeves bored out correctly at work since Silver Project accidentally missed an operation on them. The funny thing is that the machinist at work didn't bore them all the way through=( Today I will be running a 15/32 bit all the way through so that I can bolt the trailing arms up. I decided I will do the wheel bearing while they're mounted on the car because the car really needs to roll to get the bay welded up at my friends shop. The bushing went in smooth as butter this time though=D
I then decided that since I got the euro glovebox in, why not tackle the driverside cubby. Of course there was yet another stupid metal pad.
Then of course a bracket had to be welded to the frame to keep me from a straight bolt on install. (That polkadotted rusty bracket)
I decided that a dremel was smarter than an angle grinder this time.
After that was off the piece fit well=)
I did notice that you can see through the opening below the column. I believe that is because the metal pad covered that a little before. I'm going to make a little plate to sit there to pretty it up.
Tonight I will be out at the shop painting the barrels more, installing the trailing arms, and possibly painting the CV axle shafts. I will also be doing a little fiberglass repair and shaving on some parts. I'll show you what I mean tomorrow=)
Why didnt you make some nice bundt cakes with those wheels before painting them, sheesh. what the hell, those are huge. You're gonna be front and center on StanceWorks in no timeÂ
O_____________O
You are a silly man=D
