  4. Does your car have working A/C
34 Posts 26 Posters 526 Views 1 Watching
  • camarokC
    camarokC
    camarok
    540 a/c rules
    KEVIN
    BMW CCA # 416146
    sudo kill -KILL cupholders
    CDV Free, 545i Shifter and ///M Weighted Shift knob.
    Member of DSC Module Failure Club $$ :(
    deathwarden5 said:
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
      kind of.
      • Ryan...R
        Ryan...R
        Ryan...
        Subaru AC dominates. Its the first car I've ever used it in, because for some reason it doesn't give me headaches like my previous cars..
          in the e34 it doesn't work but probably just needs a recharge.  will be doing that for the summer.  i took my e30s with no AC on many summer road trips and it sucked balls to sit in a pool of sweat. for everyday driving its fine.
            Heard that
            • need4speed1299N
              need4speed1299N
              need4speed1299
              Btw, r12 > r134a. Its a thicker gas and blows snow out the vents. Its hard to find, but its out there... ;)
              • jockhater2J
                jockhater2J
                jockhater2
                1982 bmw yes.
                1991 jetta no. I removed it in place for a 2nd alternator
                • StewCrewS
                  StewCrewS
                  StewCrew
                  Can I vote both yes and rage drifting, please?
                    NO
                    you can only vote ONCE
                    make it count
                    I'm in for rage drifing
                      looks like my late model had r134a from the factory, so hopefully the $30 recharge kit will solve this issue and put me in the 'no shweaty balls' category
                      • damnboy037D
                        damnboy037D
                        damnboy037
                        No on all three!
                        99 M3 320rwhp @ 6psi
                        95 M3 s50b32
                          I used "Freeze 12" as an R12 substitute on my Camry before it was legal to sell refrigerant at parts stores (Amazon wouldnt allow shipping to WI, I ended up getting some from out of state)  That was 3 years ago. It still works extremely well. You should have great results with it as long as you do it right.
                            Good to know! What I plan on using in my car when I redo the A/C.
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Hell yes to working a/c on the e36, but I voted rage drifting, no fucks given, yolo, brolo, etc.
                                from what i read, its just about not putting too much refrigerant in (allowing the pressure to get too high). should be pretty easy.
                                • 240sxguy2
                                  240sxguy2
                                  240sxguy
                                  Well, the refrigerant went somewhere.. so there is obviously a leak. Unless you vented the system of course.
                                    after 20 years, even a miniscule leak would result in this, yes.
                                      No A/C here, took it out when rebuilding and it's still in the basement.  Just sweating on the black leather...
                                        bimmer82
                                        I love getting outta my car with a sweat stain on my back and ass..
                                        no AC no PS no Clutch fan...
                                          The car came with no belt so I was concerned the compressor was seized. Much to my surprise I threw a belt on her on Tuesday during my lunch and the ac works fine!
