  4. Anyone wanna see a Chummins in the making?
31 Posts 9 Posters 0 Views 1 Watching
  • C
    C
    Chadley
    UPDATE!!!!!!!!!!!!!!!!!
    Chris and Zach have seen this goodness....
    Here we go, old motor getting ready to pull
    And its out!
    See gentlemen, you have to get the ladies help. They clean grease very well
    These three bolts on the diff need countersinking. Otherwise they will rub against the oil pan
    Base plate for the motor mounts. Bolt and weld
    Yummy weld
    Got some clean engine bay, and some flat black
    Sliding that sucker in. She was a tight fight no doubt. The oil pan was very close to the diff, it took the just right amount of angle, swearing, and prying to get it in
    • C
      C
      Chadley
      Started the day getting the cab ready for the 5 speed. Cut the hole in the carpet, and started grinding away
      With the bellhousing bolted to the motor, the transmission had to go in seperately. Seemed easy, the tranny to bellhousing connection only has 4 bolts. Wasnt even close to easy, as it turns out muscling a 300lb transmission into a 1 1/4" hole is harder than it seems. We had to cut this slit to get the shifter into the cab, no big deal.
      Forget to take pics of the rest, oh well. Next conundrum, we noticed the motor was slightly offset. This is why
      Fixed with...
      And I once again forgot to take a picture of the finished product :)
      However...
      5 speed is in. Have to get a new spring for my clutch pedal assembly, then I can finish my linkage. With that, the slave will be hooked up. Gotta reuse the Chrysler slave rod with the GM cylinder. Or just the dodge slave. Who knows.
      Gentlemen, I present...
      CHUMMINS!!!!
        Glad I could help with this beast!
          looking better with every update!!
          nice work man
            Where be the progress? Haven't heard from ya in a while.
            • C
              C
              Chadley
              Been busy. Havent been too good with pictures. Update soon!!
                • C
                  C
                  Chadley
                  ^fuck. i want some popcorn
                  • C
                    C
                    Chadley
                    I'm gonna be that 15 year old dd34 tease.
                    It is driving now. Has some boost leaks, but regardless. Chris and I drove kt
                      pics or it didn't happen
                      Don+t+forget+post+pics+or+it+didn+t+happ
                      • C
                        C
                        Chadley
                        ^ cock
                        Lol
                        Soon. Driving It more tonignt. Woohoo
                          I still gotta upload the videos from thursday too
