  4. Anyone wanna see a Chummins in the making?
31 Posts 9 Posters 626 Views 1 Watching
  • C
    C
    Chadley
    Brian said:
    Cummins=CAT motors, and they're more reliable then the chevy motor.
    Best parts from each american diesel truck:
    Ford=body
    Chevy= Drivetrain/axles etc
    Dodge= Motor
    No.
    Cummins is its own company, has nothing to do with cat or chrysler. Cummins has a deal with dodge to exclusively use cummins in RAM (not with ford or Chevy). Kind of like how Allison has a contract with GM to only use their transmissions in the light duty market.
    Cummins has been around for around 80 years. One of the best diesels on the market. Easiest to maintain and modify too, not o mention cheapest to modify.
    Also, ford bodies are shit. They rot worse than Chevys.
    Ford is good for their axles. That's it. And that's only cause they use DANA axles.
    Dodge is only good for the Cummins that comes in it. Pretty much garbage everywhere else.
    Chevy has the nicest interior by far. Best driving truck in my opinion. But, they rot too, and have quirks because of their IFS that dodge and ford don't use.
    By the way, CUMMINS IS NOT OWNED BY DODGE OR CAT
    • I
      I
      industrialsized
      moreover the 6bt/4bt was designed jointly between cummins and case tractor, doge had nothing to do with the motor other than buying it a full 5 years after it was in production
      • I
        I
        industrialsized
        ohh and Caterpillar motors are in chevys...
        also chevy axles are the strongest light truck axles dana60 and corp14 ff ford also uses dana 60's but its a counter rotation highpinion witch is very slightly weaker then the chev variant and ford uses a stearling 10.25 in the rear that has a 1/4" smaller ring gear but a slightly larger pinion bearing so strengh would be about the same but the chevys win because they have higher spline counts on the axles and pinion yoke
        Facts, every one should try they're Awesome!
        • C
          C
          Chadley
          Dustin, i'ma shoot ya a call here real soon
          UPDATE!!!!
          Heres from where I left off last time... I pounded the aluminum case over the dowel pin, so it will stay in place regardless of the plate.
          Some red loctite, and...
          Something interesting. Either Chrysler was too lazy to paint the timing cover off the motor, or someone replaced it and didnt do a good job painting it. You can see the tan industrial color you find on motors out of buses or drill rigs.
          regardless, cover painted and installed
          Turbo oil fitting installed. Got it clocked, re-welded the nessacary parts, and it is installed now.
          And before you know it....
          Phase 1 of 3 is complete :) Friday I get the transmission, and the 6.5/4L80E comes out. Cummins should be on its way in come saturday
            this thing is gonna be sweet
            • C
              C
              Chadley
              UPDATE!!!!!!!!!!!!!!!!!
              Chris and Zach have seen this goodness....
              Here we go, old motor getting ready to pull
              And its out!
              See gentlemen, you have to get the ladies help. They clean grease very well
              These three bolts on the diff need countersinking. Otherwise they will rub against the oil pan
              Base plate for the motor mounts. Bolt and weld
              Yummy weld
              Got some clean engine bay, and some flat black
              Sliding that sucker in. She was a tight fight no doubt. The oil pan was very close to the diff, it took the just right amount of angle, swearing, and prying to get it in
              • C
                C
                Chadley
                Started the day getting the cab ready for the 5 speed. Cut the hole in the carpet, and started grinding away
                With the bellhousing bolted to the motor, the transmission had to go in seperately. Seemed easy, the tranny to bellhousing connection only has 4 bolts. Wasnt even close to easy, as it turns out muscling a 300lb transmission into a 1 1/4" hole is harder than it seems. We had to cut this slit to get the shifter into the cab, no big deal.
                Forget to take pics of the rest, oh well. Next conundrum, we noticed the motor was slightly offset. This is why
                Fixed with...
                And I once again forgot to take a picture of the finished product :)
                However...
                5 speed is in. Have to get a new spring for my clutch pedal assembly, then I can finish my linkage. With that, the slave will be hooked up. Gotta reuse the Chrysler slave rod with the GM cylinder. Or just the dodge slave. Who knows.
                Gentlemen, I present...
                CHUMMINS!!!!
                  Glad I could help with this beast!
                    looking better with every update!!
                    nice work man
                      Where be the progress? Haven't heard from ya in a while.
                      • C
                        C
                        Chadley
                        Been busy. Havent been too good with pictures. Update soon!!
                          • C
                            C
                            Chadley
                            ^fuck. i want some popcorn
                            • C
                              C
                              Chadley
                              I'm gonna be that 15 year old dd34 tease.
                              It is driving now. Has some boost leaks, but regardless. Chris and I drove kt
                                pics or it didn't happen
                                Don+t+forget+post+pics+or+it+didn+t+happ
                                • C
                                  C
                                  Chadley
                                  ^ cock
                                  Lol
                                  Soon. Driving It more tonignt. Woohoo
                                    I still gotta upload the videos from thursday too
