    Sell me your Breytons.
      No they for me=) On a side note. Just spoke with Shaun. He cleared the wheel yesterday, but it was his first time using this new powder. They ended up coming out like poop. He is now starting over. I offered to pay a little extra becasue I feel bad, but he kindly declined. They should be done tomorrow or this weekend I am hoping.
        I got a little done on Saturday, but it doesn't look like much.
        I started off by painting the other side of the block. Both sides turned out really well.
        The color came out brighter and more silver than what I wanted, but it will work well with the rest of the colors.
        Most of the rest of the day was spent with a propane torch and wire brush. I still have a lot of seam sealer to get out of little nooks and crannys. I'm really hoping I can get it out soon so that I can weld the seams up, grind them flat, and then smooth out the whole bay. I really want to be done with that so that I can just fit the wheels, and then send the car off for paint.
        I'll hopefully be ordering a ton of parts this week so I can slowly cross things off of my list. I also need to replace a wheel bearing in the rear so that I can put the subframe back in.
        Last thing I got done was a little cleaning on the steering rack. I ran out of brake cleaner=(
        I'm hoping some more exciting updates will come sooner than later.
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          earl it was fun watching you flip out at the gas pump on saturday. hahahahaĀ
          oh and this...
            First time I ever planked. Strut mount nuts hurt in the shins.
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              funniest part was when i was outside and you said "hey john, can you take a picture of me planking?" i had a confused look on my face, but then iĀ realizedĀ that it was earl who asked the question.
                I honestly don't know how I got the idea. Lol
                  I just noticed I have more posts than Ryan now=)
                    I got another little chunk of work done yesterday. I wanted to smooth out all of the old bracket mounting points. I grabbed a 120 grit flap wheel and went to town.
                    I then got most of the seam sealer finally removed from the corners. Some of it is still in that very tight corner. I think I'll need to use a pick to get that out.
                    I then put the subframe bushings in.
                    I went to put the trailing arm bushings in and ran into a snag. I got the end with the sleeve pressed in with the help of a hammer, but I could not get the other end to come in any farther than pictured=( I didn't happen to have a c clamp handy, so I will be using one today to get them fully seated.
                    I will be going to the shop today after work, and also on Sunday. I'll post the updates Monday=)
                      nice!
                      • JeffJ
                        JeffJ
                        Jeff
                        looking great earl!
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          excited to see this thing in one piece!
                            If it ever gets back in one piece=\ I'm sick of little setbacks. Lol
                              Your bushings look like skateboard wheels.
                                Lol Both urethane:P What durometer bushings did you get?
                                  80
                                    These are 75. Does 80 feel harsh at all?
                                      Absolutely not. It feels stock to me. If I ever replace them I might even try the 95A
                                        I should have went with the 95 then:(
                                          comfort and performance can co-exist. Just because something stiffer exists doesn't necessarily make it better Ā or higher performance. The main goal is to keep the trailing arms from going toe-out under braking and decel. You would have to be tracking the car pretty hard / competitively to complain about toe-out problems with good stock bushings.
