  3. BMW Discussion
  4. Euro Engine
Euro Engine
44 Posts 17 Posters 839 Views 1 Watching
    gsxify
    Talk to this guy.
    http://www.abloriginalparts.com/
    2c569698-d9c7-4c7d-95f2-e176a1893935zps
    • AvusHatesConesA
      AvusHatesConesA
      AvusHatesCones
      I vote supercharger, it fits the character of the car much better than a big torque monster V8. However, if you do consider the LSx swap, talk to Rawsomotion on here. He's done a few swaps, granted in other cars but I'm sure he could give you some estimates on cost/labor etc.
      http://www.rawsomotion.com/
      Silver Grey E46 M3
        Blaine0002
        you cant just 'slap a turbo kit' on an s50/52 and expect to get tooooo much out of it.
        • damnboy037D
          damnboy037D
          damnboy037
          ABL has a stand alone system that makes engine swapping worth it, I sent my euro ecu to Alex to disable my EWS (should've had him install The Alpha N tune also).
          99 M3 320rwhp @ 6psi
          95 M3 s50b32
          • K
            K
            krautuner
            I've never done any engine swaps but the subject has always fascinated me.
            Has anyone swapped a 540i motor into a 3-series, does that make since?
            e2526838-2d06-47c6-87b1-e8cf6c8c570ezps
              http://www.r3vlimited.com/board/showthread.php?t=257138
              • StewCrewS
                StewCrewS
                StewCrew
                JGood's restoration/build thread is one of the most impressive things I've seen. So cool!
                  Pretty sure there was a article in roundel about a M60 swapped E30 not too long ago. I've seen it done on the internets too
                    m60 into e30 is a bad idea if you ask me.  weighs a shit ton, not enough room in the e34 chassis, let alone the e30 chassis for it, bad gas mileage, less reliable and more expensive to fix, and only 50hp more than a regular old s50.
                    • K
                      K
                      krautuner
                      ...and that's why your handle is straight6pwr :rolleyes:
                      I'd do a HP build in this order 1.Supercharger 2.M60 3.Turbo, simply because I like me a nice exhaust note.
                        I think swapping in an S14 motor and detuning it would be your best bet here in all reality.
                        • K
                          K
                          krautuner
                          One of my favorite s14 cars...
                          2e210m8.jpgO
                          • Ryan...R
                            Ryan...R
                            Ryan...
                            I was averaging almost 25mpg with 80% hwy driving in my 540i. Ran like a top, 128k miles. I imagine in a lighter chassis (like the e36) it wouldn't be unreasonable to get 26-27, which isn't much worse than your typical e36 325i gets anyway.
                            • K
                              K
                              krautuner
                                the m60s are fine when cruising at constant speeds, but throw in high revs/stop and go and it all goes to hell. no one is going to swap an m60 into an e30 and then use it on for 80% highway driving.  driving enthusiastically with the 6banger is still going to get you 22-24mpg, but driving the m60 that way is going to be 16-18mpg.
                                my point is probably moot since im sure if you can afford to do such swaps, gas mileage isnt really important to you.
