  4. Post your mod list.
Post your mod list.
16 Posts 10 Posters 200 Views 1 Watching
  • AvusHatesConesA
    AvusHatesConesA
    AvusHatesCones
    Alright, I thought I'd start this thread for those of us a little bit too lazy to make a real build thread. This is a spot to just post up the mod list for your car.
    So I'll start off:
    1995 E36 M3
    Engine/performance/drivetrain
    RMS catback
    Custom made dual 2’’ catless midsection
    SS rep headers
    Gruppe M carbon Kevlar cold air intake
    21.5lb fuel injectors
    Active AutoWerke ECU tune
    E46 330 5spd BMWperformance short shift kit
    F1 racing chromoly light weight flywheel
    E34 M5 sprung hub clutch
    UUC enforced transmission bushings
    Dr. Vanos stage 2 coated gear vanos
    Mechanical fan delete with low temp thermostat and fan switch
    Stewart water pump
    Suspension/Brakes/wheels tires
    ISC coilover system
    550lb front springs
    650lb rear springs
    ISC camber plates
    Bimmerworld camber shims (for additional camber)
    Poly swaybar bushings
    PowerFlex 2 piece hybrid FCAB bushings
    UUC 3 position adjustable swaybars
    Underbody X brace
    Bimmerworld rotors
    PFC Z rated pads front and rear
    Motul 600 brake fluid
    Kosei K1 racing wheels
    Bridgestone RE11 tires.
    Interior.
    Sparco Mod 68 steering wheel
    Momo steering wheel adaptor
    Custom made aluminum floor mounts
    OMP side mounts (replacing crappy no name mounts)
    Bride Vios III low max seats (driver and passenger)
    Schroth 4 point harnesses (driver and passenger)
    IO Port racing harness bar
    Sunroof delete (currently under progress)
    100% empty trunk (aside from battery)
    Sound deadening removal
    (Possible stereo removal)
    (Plenty of other weight removal tactics that I’m too lazy to type right now but might add that to the thread later.)
    2004 E46 M3
    Engine/performance/suspension/Brakes/wheels
    Gruppe M carbon fiber and Kevlar cold air intake
    Magnaflow exhaust
    Auto Solutions 30% short shift Kit
    BMW performance weighted aluminum and alcantara shift knob
    Front and rear StopTech SportStop Brake Rotors
    Front and rear StopTech Stainless Steel Brake Lines
    Front and rear StopTech Street Performance Brake Pads
    SGT coilover system
    Swapped strut hats up front for about -2.8 degrees of camber
    19’’ CSL reps 19x8.5 et40 front 19x9.5 et22 rear. 245 front 285 rear tires.
    Interior
    Alcantara and aluminum E brake handle
    Previously mentioned BMW performance weighted aluminum and alcantara shift knob
    Alcantara shift boot and ebrake boot
    Euro spec center counsel
    Dynavin V5 in dash nav
    ZCP aluminum cube dash and door trim
    (soon to get Coby steering wheel)
    Exterior
    Eagle eyes turn signals
    Smoked side markers
    Matte black front grilles
    Matte black side grilles
    Lightwerkz angle eyes
    CSL style front carbon fiber splitters
    Previously mentioned CSL rep wheels.
    Post up what chya got!
    Silver Grey E46 M3
      1988 535I E28:
      Engine/driveline/suspension/brakes:
      Spark plugs
      2.5" header back, anodized 1-piece exhaust. no cat, no resonator, no muffler.
      20W40 oil
      16" electric radiator fan
      larger all aluminum radiator
      transmission cooler.
      Cut springs
      Drivetrain:
      Welded diff
      Hawk Performance pads
      Interior:
      European black leather comfort interior
      swapped from power seats, to manual.
      Exterior:
      Front bumper delete
      relocated front blinkers
      black kidneys
      tail-light mod
      rusted-smashed fender
      15x7 et20 OZ Racing Fittipaldi 3 piece reps
      (Coming soon; fancy exhaust pipe tip)
      My car's stupid simple, and I really haven't done many mods really. I don't even have a CAI :(
      • StewCrewS
        StewCrewS
        StewCrew
        I love these kinds of threads.  Even though I already have a running build thread, its fun to list everything out.
        1984 325e
        Engine
        Swapped to M50B25TU
        ARP headstuds
        VAC .070" MLS head gasket
        Brand new gaskets top to bottom
        TMS chip
        Custom engine plates (I guess youd call them? Makes the bay look a lot cleaner)
        Some shiny headers
        Detachable radiator core support
        TMS under-drive pulleys
        Wheels/Suspension/Steering/Ect
        17x7 17x9 XXR 962
        BC type BR coilovers with custom 10k/12k rates
        New inner/outer tie rods
        New inner/outter ball joints
        New swaybar bushings
        Inner tie rod spacers
        Welded 3.73 diff
        Custom hard brake lines
        80mm extended lug studs
        20mm spacers up front and 5mm spacers in back
        Ireland Engineering front strut bar
        Exterior
        Tucked diving boards
        Late model valence with IS lip
        Cracked reap bumper
        Some zipties
        Ellipsoid  projectors
        All red tails
        Interior
        Z3 short shifter
        NRG Hub
        NRG 2.0 quick release
        NRG Deep wheel
        CNC staging brake routed as a hydro ebrake with custom samurai sword handle
        Generic bucket seats some previous owner welded right to the floor
        • AvusHatesConesA
          AvusHatesConesA
          AvusHatesCones
          1984 325e
          Engine
          Swapped to M50B25TU
          ARP headstuds
          TMS chip
          Some shiny headers
          17x7 17x9 XXR 962
          Welded 3.73 diff
          Exterior
          Cracked reap bumper
          Some zipties
          All red tails
          Interior
          Z3 short shifter
          NRG Hub
          NRG Deep wheel
          Zip ties are one of my favorite mods! :)
          Silver Grey E46 M3
          • StewCrewS
            StewCrewS
            StewCrew
            Hahahah right?  Theres quite a few.  The joys of having a car built to hit stuff.
              1989 E30
              it's slow
              • JeffJ
                JeffJ
                Jeff
                i did a gas tank delete mod
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                • StewCrewS
                  StewCrewS
                  StewCrew
                  "Im gonna do a waterpump delete" - Earl
                    Here we go...
                    1995 M3 - BMW Individual Arctic Gray
                    Dinan Powerdyne Supercharger
                    Dinan throttle body
                    Cometic MLS headgasket
                    ARP head studs
                    Long tube headers
                    Catless mid pipe
                    Remus exhaust
                    PWR aluminum radiator
                    Ground Control coilovers w/Koni adjustable shocks
                    Dinan camber plates
                    Dinan sway bars
                    Poly Motor and Transmission mounts
                    Brembo Grand Turismo 332mm 4 piston front brakes
                    Braided stainless brake lines
                    OEM BMW Motorsport Euro floating rear rotors
                    Kirk Racing 4 point roll bar
                    Racetech 1000 seats
                    VAC aluminum floor mounts
                    MCI side mounts
                    Schroth Profi II ASM 5 point harnesses
                    Momo Mod 78 steering wheel
                    ZHP shift knob
                    VDO boost gauge
                    Aluminum under tray
                    LTW splitters
                    Smoked side markers
                    OZ Racing Hamann PG1 wheels, facemount, staggered 17x8.5 and 17x9
                    Airbag delete, rear seat delete, removed sound deadening, wiper delete
                    that's all that comes to mind for now, probably missing a few things
                    2000 323iT Sahara Beige
                    FK coilovers
                    E46 M3
                    OEM BMW style 397 wheels off F30 2012 328i sport 18x8 powdercoated gloss black
                    OEM Metallic Black interior trim
                    OEM Xenon headlights retrofitted
                    Gloss black roof
                    Roof rack delete
                    Smoked Corners
                    Red out tails
                    Powdercoated black OEM exhaust tips
                    20% tint
                    1999 328i Titanium Silver
                    Style 79 17" wheels
                    H&R sport cup kit coming this weekend along with E46 M3 vert shock mounts
                    • JeffJ
                      JeffJ
                      Jeff
                      ha earl
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        1991 325i
                        Auto to manual swap.
                        and 1 or 2 other things
                          read: "post your penis size"
                          mine is 17x8 with an offset of 20 wrapped in 235/45r17 continental condomsports
                          • AvusHatesConesA
                            AvusHatesConesA
                            AvusHatesCones
                            More like, post how much time, money, blood and sweat you thought was a good idea to pour into your 10 - 30 year old BMW  :P  But isn't that the reason we're all here? Because we still love doing that?
                            Silver Grey E46 M3
                            • merlM
                              merlM
                              merl
                              NO
                                very true.
                                • e92boostE
                                  e92boostE
                                  e92boost
                                  2007 BMW 335i
                                  Engine-
                                  Jb4 G5 iso
                                  Riss Racing catless downpipes
                                  Dinan Free flow exhaust
                                  Helix Front mount intercooler
                                  Cp-E dual cone intake
                                  Walbro Lpfp upgrade (to handle high mix e85)
                                  Devils own meth kit (removed for now)
                                  Suspension/rear drivetrain-
                                  H&R coilovers
                                  E93 M3 front and rear sway bars
                                  Wavetrac LSD
                                  Exterior-
                                  M3 front bumper converted (no fogs)
                                  Vorstiener CF front splitter
                                  Carbon fiber hood
                                  LCI tail lights
                                  Carbon fiber roof
                                  Carbon fiber trunk
                                  Shadowline trim
                                  Matte black kidney grille
                                  Interior-
                                  2011 M3 novillo interior, door cards, speed cloth and novillo seats front and rear.
                                  Euro split arm rest
                                  Logic7 sound
                                  BMW performance V2 electronic steering wheel
                                  BMW performance alcantara shift boot
                                  BMW performance alcantara ebrake boot & handle
                                  ZHP shift knob
                                  Wheels-
                                  O.Z. Ultraleggera 18x8 18x9
                                  Michelin pilot super sports 225/35/18 255/30/18
                                  bms spacers
                                  There's probably alot more I haven't named.
                                  Need to get better photos my sig pics from 3 years ago lol.
                                  Will update soon.
                                  Can't wait to get to a meet! :)
                                  Ben H.
