<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Post your mod list.]]></title><description><![CDATA[<p dir="auto">Alright, I thought I'd start this thread for those of us a little bit too lazy to make a real build thread. This is a spot to just post up the mod list for your car.</p>
<p dir="auto">So I'll start off:</p>
<p dir="auto"><strong>1995 E36 M3</strong></p>
<p dir="auto"><strong>Engine/performance/drivetrain</strong></p>
<p dir="auto">RMS catback</p>
<p dir="auto">Custom made dual 2’’ catless midsection</p>
<p dir="auto">SS rep headers</p>
<p dir="auto">Gruppe M carbon Kevlar cold air intake</p>
<p dir="auto">21.5lb fuel injectors</p>
<p dir="auto">Active AutoWerke ECU tune</p>
<p dir="auto">E46 330 5spd BMWperformance short shift kit</p>
<p dir="auto">F1 racing chromoly light weight flywheel</p>
<p dir="auto">E34 M5 sprung hub clutch</p>
<p dir="auto">UUC enforced transmission bushings</p>
<p dir="auto">Dr. Vanos stage 2 coated gear vanos</p>
<p dir="auto">Mechanical fan delete with low temp thermostat and fan switch</p>
<p dir="auto">Stewart water pump</p>
<p dir="auto"><strong>Suspension/Brakes/wheels tires</strong></p>
<p dir="auto">ISC coilover system</p>
<p dir="auto">550lb front springs</p>
<p dir="auto">650lb rear springs</p>
<p dir="auto">ISC camber plates</p>
<p dir="auto">Bimmerworld camber shims (for additional camber)</p>
<p dir="auto">Poly swaybar bushings</p>
<p dir="auto">PowerFlex 2 piece hybrid FCAB bushings</p>
<p dir="auto">UUC 3 position adjustable swaybars</p>
<p dir="auto">Underbody X brace</p>
<p dir="auto">Bimmerworld rotors</p>
<p dir="auto">PFC Z rated pads front and rear</p>
<p dir="auto">Motul 600 brake fluid  </p>
<p dir="auto">Kosei K1 racing wheels</p>
<p dir="auto">Bridgestone RE11 tires.</p>
<p dir="auto"><strong>Interior.</strong></p>
<p dir="auto">Sparco Mod 68 steering wheel</p>
<p dir="auto">Momo steering wheel adaptor</p>
<p dir="auto">Custom made aluminum floor mounts</p>
<p dir="auto">OMP side mounts (replacing crappy no name mounts)</p>
<p dir="auto">Bride Vios III low max seats (driver and passenger)</p>
<p dir="auto">Schroth 4 point harnesses (driver and passenger)</p>
<p dir="auto">IO Port racing harness bar</p>
<p dir="auto">Sunroof delete (currently under progress)</p>
<p dir="auto">100% empty trunk (aside from battery)</p>
<p dir="auto">Sound deadening removal</p>
<p dir="auto">(Possible stereo removal)</p>
<p dir="auto">(Plenty of other weight removal tactics that I’m too lazy to type right now but might add that to the thread later.)</p>
<p dir="auto"><strong>2004 E46 M3</strong></p>
<p dir="auto"><strong>Engine/performance/suspension/Brakes/wheels</strong>  </p>
<p dir="auto">Gruppe M carbon fiber and Kevlar cold air intake</p>
<p dir="auto">Magnaflow exhaust</p>
<p dir="auto">Auto Solutions 30% short shift Kit</p>
<p dir="auto">BMW performance weighted aluminum and alcantara shift knob</p>
<p dir="auto">Front and rear StopTech SportStop Brake Rotors</p>
<p dir="auto">Front and rear StopTech Stainless Steel Brake Lines</p>
<p dir="auto">Front and rear StopTech Street Performance Brake Pads</p>
<p dir="auto">SGT coilover system</p>
<p dir="auto">Swapped strut hats up front for about -2.8 degrees of camber</p>
<p dir="auto">19’’ CSL reps 19x8.5 et40 front 19x9.5 et22 rear. 245 front 285 rear tires.</p>
<p dir="auto"><strong>Interior</strong></p>
<p dir="auto">Alcantara and aluminum E brake handle</p>
<p dir="auto">Previously mentioned BMW performance weighted aluminum and alcantara shift knob</p>
<p dir="auto">Alcantara shift boot and ebrake boot</p>
<p dir="auto">Euro spec center counsel</p>
<p dir="auto">Dynavin V5 in dash nav</p>
<p dir="auto">ZCP aluminum cube dash and door trim</p>
<p dir="auto">(soon to get Coby steering wheel)</p>
<p dir="auto"><strong>Exterior</strong></p>
<p dir="auto">Eagle eyes turn signals</p>
<p dir="auto">Smoked side markers</p>
<p dir="auto">Matte black front grilles</p>
<p dir="auto">Matte black side grilles</p>
<p dir="auto">Lightwerkz angle eyes</p>
<p dir="auto">CSL style front carbon fiber splitters</p>
<p dir="auto">Previously mentioned CSL rep wheels.</p>
<p dir="auto">Post up what chya got!</p>
]]></description><link>https://wibimmers.com/topic/1385/post-your-mod-list.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:26 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1385.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Apr 2013 20:51:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 22:58:04 GMT]]></title><description><![CDATA[<p dir="auto">2007 BMW 335i</p>
<p dir="auto">Engine-</p>
<p dir="auto">Jb4 G5 iso</p>
<p dir="auto">Riss Racing catless downpipes</p>
<p dir="auto">Dinan Free flow exhaust</p>
<p dir="auto">Helix Front mount intercooler</p>
<p dir="auto">Cp-E dual cone intake</p>
<p dir="auto">Walbro Lpfp upgrade (to handle high mix e85)</p>
<p dir="auto">Devils own meth kit (removed for now)</p>
<p dir="auto">Suspension/rear drivetrain-</p>
<p dir="auto">H&amp;R coilovers</p>
<p dir="auto">E93 M3 front and rear sway bars</p>
<p dir="auto">Wavetrac LSD</p>
<p dir="auto">Exterior-</p>
<p dir="auto">M3 front bumper converted (no fogs)</p>
<p dir="auto">Vorstiener CF front splitter</p>
<p dir="auto">Carbon fiber hood</p>
<p dir="auto">LCI tail lights</p>
<p dir="auto">Carbon fiber roof</p>
<p dir="auto">Carbon fiber trunk</p>
<p dir="auto">Shadowline trim</p>
<p dir="auto">Matte black kidney grille</p>
<p dir="auto">Interior-</p>
<p dir="auto">2011 M3 novillo interior, door cards, speed cloth and novillo seats front and rear.</p>
<p dir="auto">Euro split arm rest</p>
<p dir="auto">Logic7 sound</p>
<p dir="auto">BMW performance V2 electronic steering wheel</p>
<p dir="auto">BMW performance alcantara shift boot</p>
<p dir="auto">BMW performance alcantara ebrake boot &amp; handle</p>
<p dir="auto">ZHP shift knob</p>
<p dir="auto">Wheels-</p>
<p dir="auto">O.Z. Ultraleggera 18x8 18x9</p>
<p dir="auto">Michelin pilot super sports 225/35/18 255/30/18</p>
<p dir="auto">bms spacers</p>
<p dir="auto">There's probably alot more I haven't named.</p>
<p dir="auto">Need to get better photos my sig pics from 3 years ago lol.</p>
<p dir="auto">Will update soon.</p>
<p dir="auto">Can't wait to get to a meet! <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/21589</link><guid isPermaLink="true">https://wibimmers.com/post/21589</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Thu, 18 Apr 2013 22:58:04 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 16:30:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21551">AvusHatesCones said:</a></strong></p>
<p dir="auto">More like, post how much time, money, blood and sweat you thought was a good idea to pour into your 10 - 30 year old BMW  <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" />  But isn't that the reason we're all here? Because we still love doing that? </p>
<p dir="auto">very true.</p>
]]></description><link>https://wibimmers.com/post/21574</link><guid isPermaLink="true">https://wibimmers.com/post/21574</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Thu, 18 Apr 2013 16:30:44 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 13:18:38 GMT]]></title><description><![CDATA[<p dir="auto">NO</p>
<p dir="auto"><img src="http://www.gpb.org/files/imagecache/340x255/grumpy-cat-final.jpg" alt="grumpy-cat-final.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/21558</link><guid isPermaLink="true">https://wibimmers.com/post/21558</guid><dc:creator><![CDATA[merl]]></dc:creator><pubDate>Thu, 18 Apr 2013 13:18:38 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 12:13:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21537">straight6pwr said:</a></strong></p>
<p dir="auto">read: "post your penis size"</p>
<p dir="auto">More like, post how much time, money, blood and sweat you thought was a good idea to pour into your 10 - 30 year old BMW  <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" />  But isn't that the reason we're all here? Because we still love doing that?</p>
]]></description><link>https://wibimmers.com/post/21551</link><guid isPermaLink="true">https://wibimmers.com/post/21551</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Thu, 18 Apr 2013 12:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 03:27:45 GMT]]></title><description><![CDATA[<p dir="auto">read: "post your penis size"</p>
<p dir="auto">mine is 17x8 with an offset of 20 wrapped in 235/45r17 continental condomsports</p>
]]></description><link>https://wibimmers.com/post/21537</link><guid isPermaLink="true">https://wibimmers.com/post/21537</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Thu, 18 Apr 2013 03:27:45 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 01:56:40 GMT]]></title><description><![CDATA[<p dir="auto">1991 325i</p>
<p dir="auto">Auto to manual swap.</p>
<p dir="auto">and 1 or 2 other things</p>
]]></description><link>https://wibimmers.com/post/21533</link><guid isPermaLink="true">https://wibimmers.com/post/21533</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 18 Apr 2013 01:56:40 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 01:36:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21520">StewCrew said:</a></strong></p>
<p dir="auto">"Im gonna do a waterpump delete" - Earl</p>
<p dir="auto">ha earl</p>
]]></description><link>https://wibimmers.com/post/21529</link><guid isPermaLink="true">https://wibimmers.com/post/21529</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 18 Apr 2013 01:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 00:50:00 GMT]]></title><description><![CDATA[<p dir="auto">Here we go...</p>
<p dir="auto"><a href="http://s935.photobucket.com/user/nicepull6485/media/m3edit2_zpsb85a5708.jpg.html" rel="nofollow ugc"><img src="http://i935.photobucket.com/albums/ad194/nicepull6485/m3edit2_zpsb85a5708.jpg" alt="m3edit2zpsb85a5708.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">1995 M3 - BMW Individual Arctic Gray</p>
<p dir="auto">Dinan Powerdyne Supercharger</p>
<p dir="auto">Dinan throttle body</p>
<p dir="auto">Cometic MLS headgasket</p>
<p dir="auto">ARP head studs</p>
<p dir="auto">Long tube headers</p>
<p dir="auto">Catless mid pipe</p>
<p dir="auto">Remus exhaust</p>
<p dir="auto">PWR aluminum radiator</p>
<p dir="auto">Ground Control coilovers w/Koni adjustable shocks</p>
<p dir="auto">Dinan camber plates</p>
<p dir="auto">Dinan sway bars</p>
<p dir="auto">Poly Motor and Transmission mounts</p>
<p dir="auto">Brembo Grand Turismo 332mm 4 piston front brakes</p>
<p dir="auto">Braided stainless brake lines</p>
<p dir="auto">OEM BMW Motorsport Euro floating rear rotors</p>
<p dir="auto">Kirk Racing 4 point roll bar</p>
<p dir="auto">Racetech 1000 seats</p>
<p dir="auto">VAC aluminum floor mounts</p>
<p dir="auto">MCI side mounts</p>
<p dir="auto">Schroth Profi II ASM 5 point harnesses</p>
<p dir="auto">Momo Mod 78 steering wheel</p>
<p dir="auto">VDO boost gauge</p>
<p dir="auto">Aluminum under tray</p>
<p dir="auto">LTW splitters</p>
<p dir="auto">OZ Racing Hamann PG1 wheels, facemount, staggered 17x8.5 and 17x9</p>
<p dir="auto">Airbag delete, rear seat delete, removed sound deadening, wiper delete</p>
<p dir="auto">that's all that comes to mind for now, probably missing a few things</p>
<p dir="auto"><a href="http://s935.photobucket.com/user/nicepull6485/media/20130223_164201_zpsa8bade82.jpg.html" rel="nofollow ugc"><img src="http://i935.photobucket.com/albums/ad194/nicepull6485/20130223_164201_zpsa8bade82.jpg" alt="20130223164201zpsa8bade82.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">2000 323iT Sahara Beige</p>
<p dir="auto">FK coilovers</p>
<p dir="auto">E46 M3</p>
<p dir="auto">OEM BMW style 397 wheels off F30 2012 328i sport 18x8 powdercoated gloss black</p>
<p dir="auto">OEM Metallic Black interior trim</p>
<p dir="auto">OEM Xenon headlights retrofitted</p>
<p dir="auto">Gloss black roof</p>
<p dir="auto">Roof rack delete</p>
<p dir="auto">Smoked Corners</p>
<p dir="auto">Red out tails</p>
<p dir="auto">Powdercoated black OEM exhaust tips</p>
<p dir="auto">20% tint</p>
<p dir="auto"><a href="http://s935.photobucket.com/user/nicepull6485/media/20130302_140038_zps8ae8d882.jpg.html" rel="nofollow ugc"><img src="http://i935.photobucket.com/albums/ad194/nicepull6485/20130302_140038_zps8ae8d882.jpg" alt="20130302140038zps8ae8d882.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">1999 328i Titanium Silver</p>
<p dir="auto">Style 79 17" wheels</p>
<p dir="auto">H&amp;R sport cup kit coming this weekend along with E46 M3 vert shock mounts</p>
]]></description><link>https://wibimmers.com/post/21521</link><guid isPermaLink="true">https://wibimmers.com/post/21521</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 18 Apr 2013 00:50:00 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Thu, 18 Apr 2013 00:07:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21518">Jeff said:</a></strong></p>
<p dir="auto">i did a gas tank delete mod</p>
]]></description><link>https://wibimmers.com/post/21520</link><guid isPermaLink="true">https://wibimmers.com/post/21520</guid><dc:creator><![CDATA[StewCrew]]></dc:creator><pubDate>Thu, 18 Apr 2013 00:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 23:32:54 GMT]]></title><description><![CDATA[<p dir="auto">i did a gas tank delete mod</p>
]]></description><link>https://wibimmers.com/post/21518</link><guid isPermaLink="true">https://wibimmers.com/post/21518</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 17 Apr 2013 23:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 23:07:11 GMT]]></title><description><![CDATA[<p dir="auto">1989 E30</p>
<p dir="auto">it's slow</p>
]]></description><link>https://wibimmers.com/post/21513</link><guid isPermaLink="true">https://wibimmers.com/post/21513</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 17 Apr 2013 23:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 22:06:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21501">AvusHatesCones said:</a></strong></p>
<p dir="auto">Zip ties are one of my favorite mods! <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Hahahah right?  Theres quite a few.  The joys of having a car built to hit stuff.</p>
]]></description><link>https://wibimmers.com/post/21504</link><guid isPermaLink="true">https://wibimmers.com/post/21504</guid><dc:creator><![CDATA[StewCrew]]></dc:creator><pubDate>Wed, 17 Apr 2013 22:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 21:58:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/21499">StewCrew said:</a></strong></p>
<p dir="auto">I love these kinds of threads.  Even though I already have a running build thread, its fun to list everything out.</p>
<p dir="auto">1984 325e</p>
<p dir="auto"><strong>Engine</strong></p>
<p dir="auto">Swapped to M50B25TU</p>
<p dir="auto">ARP headstuds</p>
<p dir="auto">VAC .070" MLS head gasket</p>
<p dir="auto">Brand new gaskets top to bottom</p>
<p dir="auto">TMS chip</p>
<p dir="auto">Custom engine plates (I guess youd call them? Makes the bay look a lot cleaner)</p>
<p dir="auto">Some shiny headers</p>
<p dir="auto">Detachable radiator core support</p>
<p dir="auto">TMS under-drive pulleys</p>
<p dir="auto"><strong>Wheels/Suspension/Steering/Ect</strong></p>
<p dir="auto">17x7 17x9 XXR 962</p>
<p dir="auto">BC type BR coilovers with custom 10k/12k rates</p>
<p dir="auto">New inner/outer tie rods</p>
<p dir="auto">New inner/outter ball joints</p>
<p dir="auto">New swaybar bushings</p>
<p dir="auto">Inner tie rod spacers</p>
<p dir="auto">Welded 3.73 diff</p>
<p dir="auto">Custom hard brake lines</p>
<p dir="auto">80mm extended lug studs</p>
<p dir="auto">20mm spacers up front and 5mm spacers in back</p>
<p dir="auto">Ireland Engineering front strut bar</p>
<p dir="auto">Tucked diving boards</p>
<p dir="auto">Late model valence with IS lip</p>
<p dir="auto">Cracked reap bumper</p>
<p dir="auto"><strong>Some zipties</strong></p>
<p dir="auto">Ellipsoid  projectors</p>
<p dir="auto">All red tails</p>
<p dir="auto">Z3 short shifter</p>
<p dir="auto">NRG Hub</p>
<p dir="auto">NRG 2.0 quick release</p>
<p dir="auto">NRG Deep wheel</p>
<p dir="auto">CNC staging brake routed as a hydro ebrake with custom samurai sword handle</p>
<p dir="auto">Generic bucket seats some previous owner welded right to the floor</p>
]]></description><link>https://wibimmers.com/post/21501</link><guid isPermaLink="true">https://wibimmers.com/post/21501</guid><dc:creator><![CDATA[AvusHatesCones]]></dc:creator><pubDate>Wed, 17 Apr 2013 21:58:57 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 21:47:33 GMT]]></title><description><![CDATA[<p dir="auto">I love these kinds of threads.  Even though I already have a running build thread, its fun to list everything out.</p>
<p dir="auto">Some zipties</p>
]]></description><link>https://wibimmers.com/post/21499</link><guid isPermaLink="true">https://wibimmers.com/post/21499</guid><dc:creator><![CDATA[StewCrew]]></dc:creator><pubDate>Wed, 17 Apr 2013 21:47:33 GMT</pubDate></item><item><title><![CDATA[Reply to Post your mod list. on Wed, 17 Apr 2013 21:21:32 GMT]]></title><description><![CDATA[<p dir="auto">1988 535I E28:</p>
<p dir="auto">Engine/driveline/suspension/brakes:</p>
<p dir="auto">Spark plugs</p>
<p dir="auto">2.5" header back, anodized 1-piece exhaust. no cat, no resonator, no muffler.</p>
<p dir="auto">20W40 oil</p>
<p dir="auto">16" electric radiator fan</p>
<p dir="auto">larger all aluminum radiator</p>
<p dir="auto">transmission cooler.</p>
<p dir="auto">Cut springs</p>
<p dir="auto">Drivetrain:</p>
<p dir="auto">Welded diff</p>
<p dir="auto">Hawk Performance pads</p>
<p dir="auto">Interior:</p>
<p dir="auto">European black leather comfort interior</p>
<p dir="auto">swapped from power seats, to manual.</p>
<p dir="auto">Exterior:</p>
<p dir="auto">Front bumper delete</p>
<p dir="auto">relocated front blinkers</p>
<p dir="auto">black kidneys</p>
<p dir="auto">tail-light mod</p>
<p dir="auto">rusted-smashed fender</p>
<p dir="auto">15x7 et20 OZ Racing Fittipaldi 3 piece reps</p>
<p dir="auto">(Coming soon; fancy exhaust pipe tip)</p>
<p dir="auto">My car's stupid simple, and I really haven't done many mods really. I don't even have a CAI <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/21493</link><guid isPermaLink="true">https://wibimmers.com/post/21493</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Wed, 17 Apr 2013 21:21:32 GMT</pubDate></item></channel></rss>
