  4. e21 motor swap project
87 Posts 19 Posters 0 Views 1 Watching
    I am REALLY looking forward to seeing this thing in action!
      kyletime666 said:
      i work at an engine shop so a big block was kind of a shoe in
      Brian said:
      If thats a Chevy motor, I got some bad news for you son. That isn't a big block.
      I'm pretty sure Kyle knows his way around engines :shifty:
      • kyletime666K
        kyletime666K
        kyletime666
        Thanks Earl. It is a gm though. I did all the machine work and assembly myself.
          You da man Kyle=)
            It's definitely not a big block. I can tell just by looking at the xhaust manifold. This is a small block. Probably a 400CI.
            Here's the difference:
            small block, the 2 middle exhaust ports are toghether/really close
            ctrp081201z+limitedlatemodel+small
            Big block, the ports are evenly spaced.
            Not trying to be an asshole, just clarifying. None the less this is a cool build.
            I'm also a chevy guy. I owned a 1976 Chevy C10 stepside with a 406CI stroker motor. prostock cams, built up valvetrain, billet crank, custom cam, etc.
            In for this though :)
            • kyletime666K
              kyletime666K
              kyletime666
              I am aware of all these things. I build engines for a living and have worked in an engine shop for ten years. It is not a Chevy. What you are saying about Chevy small and big blocks is correct. It is a gm and the brand of gm it is, it is considered a big block. I chose this because of the downward facing exhaust ports.
                Gm/Chevy= practically the exact same.. Comes out of the same factory
                • kyletime666K
                  kyletime666K
                  kyletime666
                  Agreed. Same basic design but this motor came out of a pontiac. Chevy and pontiac don't use the same motors. It is a big block pontiac. The head design is completely different.
                    kyletime666 said:
                    I work at an engine shop so a big block was kind of a shoe in
                    I restate this again.
                    • 240sxguy2
                      240sxguy2
                      240sxguy
                      Badass build man. I love those cars.
                        Earl, you can restate your same comment all you want. But when most people say a GM/GENERAL MOTORS "big block V8" Everyone goes, GMC/CHEVY. The pontiac route is rarely gone over. So yeah, I'll accept I was wrong. But just because he's done motors for 10 years, doesn't mean he's always right.
                        An anyone from the SBC/BBC area could have made the same mistake I did. Because that's what most GM SBC's look like.
                        • kyletime666K
                          kyletime666K
                          kyletime666
                          thats why I chose this motor. Super rare. Never been done, torque out of the ass, and the downward facing exhaust was Perfect for this car.
                            What size Pontiac motor is that?
                            • kyletime666K
                              kyletime666K
                              kyletime666
                              Stock it was 400 ci or 6.6 liters
                                cant wait to see this running!
                                  Nice. I had a 6.7L 406 stroker, they definitely have the balls to move.
                                  • kyletime666K
                                    kyletime666K
                                    kyletime666
                                    The car will wiegh probably less than 2000 when done
                                    • kyletime666K
                                      kyletime666K
                                      kyletime666
                                      ok, sometime has gone by since my last update. alot of changes had been made. here are a few pics
                                      IMAG1279zps9fb78015.jpgIMAG1268zpsefe8d637.jpgIMAG1267zpsbf9bccae.jpgIMAG1262zps8849e502.jpgIMAG1256zps60521f3a.jpg
                                      Tube Chassis is done, motor is in, just finished all the wiring. Finally got my hand made rear end. Hopefully will have it mounted this weekend. its getting close.
                                        U N C R E D I B L E
                                        fabtastic work m8!!!
                                          Getting closer man! Keep up the amazing work!
