E30 M50 tear down kinda thing
I remember removing more alternators without keys rather than with keys in my VW days. The compression of the nut against the pulley and shoulder on the shaft is generally enough to let it all work properly in absense of the key, luckily ACE hardware has keys that should fit in case you need one.
yes ,,, Impact gun in short bursts and it will come right off.
FYI -- Some of the pully/fan assemblies have a wood-ruff key ... I have managed to lose them 100% of the time so I am skeptical that they exist .. .like unicorns
Yes ... I forgot. O'Reilly has the key too
Awesome, thanks you guys. Im going to try an impact later tonight when I go back to the shop. If needed there's an O'Reilly's less than two minutes away.
Thanks Jeff!
And Brian not that I can think of off the top of my head. Nothing big at least. I know Ill need 1 of the longer bolts on the upper timing cover, since I snapped one. Other than that its just a matter of putting things back together. Ill be buying a clutch tomorrow and that should be the last of new parts
i was going to repaint my engine bay black but the grey looks better.
I didnt mind the black at first, but for whatever reason I started to really not like how dull it looked.
Also hit my first setback of reassembling. I cant find my coil pack ground plates. This really bugs me because of how organized Ive been during this entire build. I dont understand how I could misplace something like that..
what ground plates i might have some for you.
These guys:
http://www.amazon.co.uk/Engine-Earth-Ground-Plate-1738669/dp/B009KT2OT2
Theres 3 if I remember right, and they go between the coil packs.
Edit: Reading more into it, Im not even entirely sure if I need them. Pelican Doesnt mention them in their article; only the two ground straps.
Looks like Andy payed you a visit. I'd like a ride this weekend. Thanks in advance.
Tell me about these ground plates and a ride is definitely possible.
These guys:
there is 2 of them. they hold coil pack wires in the rectangle hole. you dont entirely need them but it helps with grounding a little. and i have some if you want them.
Yeah, after reading more into it I guess theyre not really ground plates at all. My motor only had 1 ground strap on it, and m50's are supposed to have 2 I guess. This might explain the random stutter problem that I sometimes had?
Also, where Im at.
When can I get you your europlates and meet you and your sexy car in person?
Hahaha, well seeing as the motor is now timed, Ill be at the shop working on it through out the weekend! Im off tomorrow around 4 and also off on weekends. The shop is just right in Waukesha off 164. Im gonna be honest with you though, its not as appealing in person xD
it could be a part of it jo to napa and get another ground strap. there should be one in the middle on cylinder 3 and at the end on cylinder 6.
would also like to see sexy car but i dont have plates for you.
