  • StewCrewS
    StewCrewS
    StewCrew
    you should have shaved it for later
    Lmao I was literally coming back to edit "I should have just shaved it for later" into my post.  Well played.
      • StewCrewS
        StewCrewS
        StewCrew
        Just trying to wrap up some last minute stuff before my motor gets timed tomorrow.  Got around to getting my exhaust manifold studs in.  Used Brian's step-by-step procedure and it worked perfect.  A pinch of loctite and torqued to NGA Nm with jam nuts and they're done.
        BD4F1596-8BA5-40C5-80C3-0A4BAD079238-105
        Also some changes in the looks of things.
        The bay is now charcoal grey, since I hated how the black looked.  Kinda going with a blue/grey theme to go with the car color and wheels.  We'll see how it actually looks.  Its a bit darker in person compared to the picture, but not by much.
        5D676CE5-97E6-40BE-A488-3443E4B6AE9A-105
        Also painted the valve cover.  I couldnt get all of the original finish off, so it looks like shit.  The point is it'll look good when the car is sliding with no hood on.
        22242E49-77EE-4AA6-A9A1-4A8AC14ED6AD-105
        Also, anyone have a tip or something to get the alternator pulley off when theres no belt on it?  Im looking to throw my TMS pulleys on tonight.
          engine bay looks good!
            Looks like my rear subframe. Good Job=)
              Love it!!!
              • StewCrewS
                StewCrewS
                StewCrew
                Thanks yall.  I like it a lot more now that theres actually color.
                As for the alt pulley, Ive read just using an impact with get it off.  So I'll give this a try later tonight.
                • merlM
                  merlM
                  merl
                  yes ,,, Impact gun in short bursts and it will come right off.
                  FYI -- Some of the pully/fan assemblies have a wood-ruff key ... I have managed to lose them 100% of the time so I am skeptical that they exist .. .like unicorns
                    I remember removing more alternators without keys rather than with keys in my VW days. The compression of the nut against the pulley and shoulder on the shaft is generally enough to let it all work properly in absense of the key, luckily ACE hardware has keys that should fit in case you need one.
                    • merlM
                      merlM
                      merl
                      Yes ... I forgot. O'Reilly has the key too
                      • StewCrewS
                        StewCrewS
                        StewCrew
                        Awesome, thanks you guys.  Im going to try an impact later tonight when I go back to the shop.  If needed there's an O'Reilly's less than two minutes away.
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          So this is kiiiiiind of a big deal.......
                          DC2A3657-66ED-4FC2-B989-EAAB05E9F343-599
                          Now please excuse me while I go put shit back on my motor! :D
                          • JeffJ
                            JeffJ
                            Jeff
                            wow looking great and i love the grey in the engine bay looks nice.
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              Is there anything else on the to-do list? or will you be driving it again after the engine is put back together and in the car?
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                Thanks Jeff!
                                And Brian not that I can think of off the top of my head.  Nothing big at least.  I know Ill need 1 of the longer bolts on the upper timing cover, since I snapped one.  Other than that its just a matter of putting things back together.  Ill be buying a clutch tomorrow and that should be the last of new parts
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  i was going to repaint my engine bay black but the grey looks better.
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                  • StewCrewS
                                    StewCrewS
                                    StewCrew
                                    I didnt mind the black at first, but for whatever reason I started to really not like how dull it looked.
                                    Also hit my first setback of reassembling.  I cant find my coil pack ground plates.  This really bugs me because of how organized Ive been during this entire build.  I dont understand how I could misplace something like that..
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      what ground plates i might have some for you.
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                      • StewCrewS
                                        StewCrewS
                                        StewCrew
                                        These guys:
                                        http://www.amazon.co.uk/Engine-Earth-Ground-Plate-1738669/dp/B009KT2OT2
                                        Theres 3 if I remember right, and they go between the coil packs.
                                        Edit: Reading more into it, Im not even entirely sure if I need them.  Pelican Doesnt mention them in their article; only the two ground straps.
                                          Looks like Andy payed you a visit. I'd like a ride this weekend. Thanks in advance.
